I've been having this issue with V3.5.1 for quite some time now. Every night my config backups run I get a failed login report should different devices each night with a failure of "Connectivity issues discarding config file".
If I go into the device details and use the validate login cirrus is able to get in just fine. Again...this is random on which device reports the error but the validation works every time I try it. My case is 7314 and has been open since May. The latest is its sitting in development...
Denny/Mark...can you guys look into this and find out when this will get fixed?
BB
