I noticed that the curent version 9.2.047 only partially support SNMPv3. What is the plan to fully integrate SNMPv3 into the tools?
Thanks.
gbockelmann - are there tools that you would like to see SNMPv3 support in that currently do not have it?
Greg
For security reasons we cannot use anything less than SNMPv3. I went through all the tools and found that several do not support SNMPv3. Here is the list:
Network SonarSNMP SweepSubnet ListAdvanced CPU LoadCPU GaugeRouter CPU LoadSNMP Real Time GraphProxy PingMIB ViewerMIB WalkUpdate System MIBRemote TCP Session ResetSNMP Brute Force AttackSNMP Dictionary AttackThere are a few others that I couldn't test some because TFTP wasn't working (probably our security again).
For security reasons we cannot use anything less than SNMPv3. I went through all the tools and found that several do not support SNMPv3. Here is the list:Network SonarSNMP SweepSubnet ListAdvanced CPU LoadCPU GaugeRouter CPU LoadSNMP Real Time GraphProxy PingMIB ViewerMIB WalkUpdate System MIBRemote TCP Session ResetSNMP Brute Force AttackSNMP Dictionary Attack
Due to a recent security audit I'm in the same boat as gbockelmann. I can no longer rely on SNMPv1/v2 for managing switches and routers. When can we expect to see full SNMPv3 support in the Engineers Toolset?
We definitely plan on getting SNMPv3 support for the functionalities mentioned above; however, which apps and what version (of Toolset) are currently being determined.
Would it be possible for you to prioritize the apps in order of importance from your points of view?
Here is my list in order of use
MIB Viewer (Used daily)MIB Walk (Used daily)Router CPU LoadSNMP Sweep SNMP Real-Time GraphCPU GaugeNetwork Sonar
I know I can't solve everyones needs, but iReasoning has a great replacement for the Solarwinds MIB Viewer, and MIB Walk utilities called the iReasoning MIB Browser. This program will do simple SNMP gets, get next, sets, MIB Walks, and get subtree, all in one nice little utility. The program also supports SNMPv3. Just something I stumbled upon when looking for a way to continue doing what we've been doing with the Solarwinds Toolset for years, but with SNMPv3.
Just an FYI here, but you can do all those things currently with the SolarWinds SNMP MIB Browser, which does support SNMPv3.
--Greg
well, its now 2009. I still dont see full support in the Engineering toolkit for v3. Can we get updates on the status please?
