Has anyone created a template for a Nortel 470 switch? It is a menu driven device, so I'm having a lot of difficulty getting it to work with Cirrus.
Thanks!
I'd be happy to work with you on the creation of a template. Can you list all the commands and screen navigations that must be executed to download the config via TFTP?
Have you reviewed the tech ref on creating templates? If so, do you have a template that you've already started for this device?
I have reviewed the tech ref, and found it to be confusing. As I said, I need to have this template completed for management review. When I purchased the product the tech rep assured me that it could handle the Nortel switches, in reading through postings on Thwack, I am starting to think that this is not the case. I am really not sure why there wouldn't be a template for the Nortel 470, it is a widely used switch.
If you could provide me with a template, it would be greatly appreciated.
Is there a template available? Or an idea of the timeframe necessary to provide one?
I'll have a template you can try tomorrow that is based on the commands you sent me. I'd like to setup a web meeting tomorrow to walk through this with you and hopefully get you to a point where you're comfortable with writing templates on your own.
BTW, is {ctrl} really a carriage return new line or do you really have to hit the CTRL button?
I've attached a template you can try.
This template did not work, please see session trace:
-->StateChange: Connecting to server<--
-->StateChange: Connected to server - idle<--
Solarwinds.Net SWTelnet9 Version 9.0.27Connected!--> ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ###########Enter Ctrl-Y to begin.****************************************************************** Ethernet Switch 470-48T ****** Nortel ****** Copyright (c) 1996-2007, All Rights Reserved ****** ESS 3.7****** HW:#05 FW:3.6.0.7 SW:v3.7.0.04 ISVN:2 ******************************************************************ProcessLogin State: 0TimerTick: mstrData=< ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ###########Enter Ctrl-Y to begin.****************************************************************** Ethernet Switch 470-48T ****** Nortel ****** Copyright (c) 1996-2007, All Rights Reserved ****** ESS 3.7****** HW:#05 FW:3.6.0.7 SW:v3.7.0.04 ISVN:2 ******************************************************************> State=3 - Connected to server - idlePending Disconnect = FalseSending to get a banner!<-- ${CTRL+Y}
-->Ethernet Switch 470-48T Main Menu IP Configuration/Setup... SNMP Configuration... System Characteristics... Switch Configuration... Console/Comm Port Configuration... Display Hardware Units... Spanning Tree Configuration... TELNET/SNMP/Web Access Configuration... Software Download... ConfiProcessLogin State: 0-->guration File... Display System Log... Reset... Reset to Default Settings... Shutdown Command... Command Line Interface... Logout...Use arrow keys to highlight option, press <Return> or <Enter> to select option.ProcessLogin State: 0TimerTick: mstrData=< ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ###########Enter Ctrl-Y to begin.****************************************************************** Ethernet Switch 470-48T ****** Nortel ****** Copyright (c) 1996-2007, All Rights Reserved ****** ESS 3.7****** HW:#05 FW:3.6.0.7 SW:v3.7.0.04 ISVN:2 ******************************************************************Ethernet Switch 470-48T Main Menu IP Configuration/Setup... SNMP Configuration... System Characteristics... Switch Configuration... Console/Comm Port Configuration... Display Hardware Units... Spanning Tree Configuration... TELNET/SNMP/Web Access Configuration... Software Download... Configuration File... Display System Log... Reset... Reset to Default Settings... Shutdown Command... Command Line Interface... Logout...Use arrow keys to highlight option, press <Return> or <Enter> to select option.> State=3 - Connected to server - idlePending Disconnect = False<--
-->IP Configuration/SetupConfigurable In Use Last BootP------------------- --------------- ---------------BootP Request Mode:In-Band Stack IP Address:In-Band Switch IP Address:In-Band Subnet Mask:Default Gateway:IP Address to Ping:Start Ping:Press Ctrl-R to return to previous menu. Press Ctrl-C to return to Main Menu.[ BootP Disabled ] ProcessLogin State: 0--> [ 0.0.0.0 ] [ 172.16.96.4 ] [ 255.255.255.0 ] [ 172.16.96.1 ] [ 172.16.96.10 ][ No ] 0.0.0.0 0.0.0.0 172.16.96.4 0.0.0.0 255.255.255.0 0.0.0.0 172.16.96.1 0.0.0.0Use space bar to display choices, press <Return> or <Enter> to select choice.ProcessLogin State: 0TimerTick: mstrData=< ### ### ########### ########## ############# ########### ### #### ### ############# ############ ############# ########### ### ##### ### ### ### ### ### ### ### ### ###### ### ### ### ### ### ### ### ### ### ### ### ### ### ############ ### ######### ### ### ### ### ### ### ########### ### ######### ### ### ###### ### ### ### ### ### ### ### ### ##### ### ### ### ### ### ### ### ### #### ############# ### ### ### ########### ########### ### ### ########### ### ### ### ########### ###########Enter Ctrl-Y to begin.****************************************************************** Ethernet Switch 470-48T ****** Nortel ****** Copyright (c) 1996-2007, All Rights Reserved ****** ESS 3.7****** HW:#05 FW:3.6.0.7 SW:v3.7.0.04 ISVN:2 ******************************************************************Ethernet Switch 470-48T Main Menu IP Configuration/Setup... SNMP Configuration... System Characteristics... Switch Configuration... Console/Comm Port Configuration... Display Hardware Units... Spanning Tree Configuration... TELNET/SNMP/Web Access Configuration... Software Download... Configuration File... Display System Log... Reset... Reset to Default Settings... Shutdown Command... Command Line Interface... Logout...Use arrow keys to highlight option, press <Return> or <Enter> to select option.IP Configuration/SetupConfigurable In Use Last BootP------------------- --------------- ---------------BootP Request Mode:In-Band Stack IP Address:In-Band Switch IP Address:In-Band Subnet Mask:Default Gateway:IP Address to Ping:Start Ping:Press Ctrl-R to return to previous menu. Press Ctrl-C to return to Main Menu.[ BootP Disabled ] [ 0.0.0.0 ] [ 172.16.96.4 ] [ 255.255.255.0 ] [ 172.16.96.1 ] [ 172.16.96.10 ][ No ] 0.0.0.0 0.0.0.0 172.16.96.4 0.0.0.0 255.255.255.0 0.0.0.0 172.16.96.1 0.0.0.0Use space bar to display choices, press <Return> or <Enter> to select choice.> State=3 - Connected to server - idlePending Disconnect = False<--
TimerTick: mstrData=<> State=3 - Connected to server - idlePending Disconnect = False<--
TimerTick: Login TimeoutDisconnected - From: 172.16.96.4
It appears we've sent the PreCommand (CTRL+Y), but we're stuck waiting for the login prompt. On other Nortel devices, we typically see a username and password prompt inline after hitting CTRL+Y.
Can you please send me screen shots of the steps required to login to the device and download the config via TFTP?
