We are looking at using LEM to capture Microsoft Failover Clustering events from the Windows Application Event log. Are these logs that LEM will be able to capture?
To chime in here - some of the logs are covered in a very generic way, just to get the most common data in to LEM. Effectively, there's some generic normalization that makes it easier for you to get data in without having to have a connector built.
However! You can submit requests to either a) create a connector for that data source (if it's a lot of unique events) or b) update our application log connector to include additional (useful) information. We'll need an evtx sample and some idea of what you're looking for.
Somebody... anybody?
Do you have any idea what the Microsoft ProviderSID might be for these events?
The LEM has a connector for the Windows Application log. It's not part of the default set that the LEM assigns to a connector when it detects a Windows platform, so you may need to add it to the agent for your server(s).
Now, will it read the app logs correctly? I'm not sure, but getting the connector up and running would be the first step to finding out.
I am in the midst of testing and what I have learned so far is as follows...
If you change the connector to get nDepth and Alert, do you see the whole message in the nDepth Raw Log Search? Would that work for what you need?
Good question, is there some specific way to search the Raw Logs? Is this the case where I need to go through the process indicated HERE?
An example of a received event is as shown below, the actual event in the Windows Event Log has a lot more data. Is it normal for LEM to truncate a bunch of information out of the log?
Right, you'll have to run through that process to get the LEM prepared to collect the raw logs or message cores.
Next, the relevant connectors need to be set to send raw data to the LEM. Either of these options will do it, but if you still want the normalized data, you should pick Alert, nDepth.
Last, you need to tell nDepth to search the raw messages. This toggle has moved around in different iterations of the console, but you'll want the mouse-over to say "Log Messages." In 5.6 and 5.7 it's in the top right corner near the Play button.
For the normalized alerts, yes. The LEM tries to reduce noise and improve the readability by trimming and formatting data to meet the needs that customers have shared with us. The ability to capture raw logs means you can always get all the data, but it's not the default selection.
Ok, I have done this before and am familiar with the process. Once that is done am I able to search, create rules, etc in all the same ways as I can with the normalized data?
P.S. You need to get the forum managers to hook you up with an "Staff" badge so folks know you work for SW.
Ah, ok, that makes sense!
Shhh! Else everyone will want one!
Unfortunately, you can't make rules or filters off the raw data. You can search it in the Explore tab. If we prove the data is coming in though, we might be able to get the connector updated to allow what you're looking for.
Okay, few more questions...
If I am getting the logs at all doesn't that prove that the data is coming in?
Also, if I configure the system for raw logs, is there a way to back that configuration out later? I understand it adds a separate database for storage of the raw logs which can have side-effects and I always like to know I can back out of a change at a later date.
BTW; thanks so much for all of this info, it's really helping out. I think I may have this thing just about figured out.
Yeah, it does prove you're getting it, but it's nice to confirm that it's our agent truncating the data and not the mysterious network gremlins or something.
It creates a database, but that database will only grow as data goes into it. The LEM does a pretty good job with partition management.
So is that to say that it can't be undone once you turn on the raw log storage capabilities?
You would turn off nDepth under the nDepth options in the SSH shell, and either leave the DB or call the helpdesk and have us drop the database partition for nDepth data.
Awesome! You have been super helpful on this.
