Yes, we are running one remote poller across a WAN to the DB server.
Here are our specs:
So how many elements do you have on that remote poller? What's the latency between it and the DB server? What are your settings for polls, statistic collection, etc?
Sorry for the questions....just seeing how different your set up is to mine. Thanks.BB
I'd be interested in how you have this working as well.I've tuned my polls per seconds below the recommended values & my polling completion percentage has increased from 98.6% to 99.1% for the remote poller.I now have it running across a lightly loaded OC12 WAN link (622mbps) to the DB with 36ms latency.However I still only record SNMP data every 1-2 hours in the CPU, Mem & Utilization graphs.
Thanks for any assistance.
apparently the "head geek" is going to do a webinar on this subject. see the top page thwack.com to register.
FYI
No...I think that webinar is talking about how to use Orion to monitor your WAN links....we are talking about how to get Orion to work with pollers of WAN links.
I tweaked the time the poller issues pings for up/down; rediscovers and stuff but that didn't help. I still have alot of gapping (dots on graphs) on my remote poller. I have to make a decision soon on what to do but my WAN link is very good and I don't see how its any different from what you have.BB
Bryan, are you seeing gaps in just SNMP collected data, or ICMP as well?My ICMP polling charts are fine (polling every 5 minutes).This proves that it can be done without gaps in the data.
Yeah....looks like pings are fine even at 5-min granularity. The snmp graphs at 5 minutes is horrible looking.BTW...what's the specs of your DB server? I'm not sure if this is hurting any but Orion repoerts the physical memory on my server is 97% utilitize (3.8GB RAM). CPU % is about 30-70% utilized. I will say that I went from a avg 10% PCU utilization to 30% once I enabled the NetFlow add-on. My server specs are ProLiant DL385 G1 (2) AMD Opteron /2.40GHz (4GB RAM).BB
FWIW, we don't recommend this kind of configuration. A few people get it to work, but the latency inevitably causes the kind of issues you are seeing.
We do appreciate the problem, and we are working on a solution that would allow to place an appropriately-sized Orion on either size of the WAN link with the ability to roll up the data from both Orions into a single console. We should have a beta that you can try out in Q1.
FWIW, we don't recommend this kind of configuration. A few people get it to work, but the latency inevitably causes the kind of issues you are seeing. We do appreciate the problem, and we are working on a solution that would allow to place an appropriately-sized Orion on either size of the WAN link with the ability to roll up the data from both Orions into a single console. We should have a beta that you can try out in Q1.
Denny...I think what your proposing would be great...I look forward to looking at it.
In the meantime I do have some questions/comments. I'm having a hard time understanding this as a latency issue. If its a latency issue with getting stuff to the DB then I'd expect the ICMP graphs to have gaps too...this is not the case. The 5 minute graphs are good and the raw data has no misses. It's just SNMP. I don't think it's a load issue on my poller either....my 2 remote pollers (over the WAN) have ~1000 & ~900 elements respectively...no where near an upper limit. From what I can see I'm missing about every 4th or 5th SNMP poll. I'm going to put a sniffer on the poller today to look at what its doing. From what I see I don't see this as a latency issue..no offense. 35 ms is very good on the WAN side and since my ping graphs are updating well I'd expect the SNMP ones to do so too. Thoughts?BB
I'd be interested in how you have this working as well.I've tuned my polls per seconds below the recommended values & my polling completion percentage has increased from 98.6% to 99.1% for the remote poller.I now have it running across a lightly loaded OC12 WAN link (622mbps) to the DB with 36ms latency.However I still only record SNMP data every 1-2 hours in the CPU, Mem & Utilization graphs.Thanks for any assistance.
NG...you say you tuned BELOW the recommended value? Was that the one provided by the polls per sec program? I'm getting ~96% completion rate on my 2 remote pollers (ones across the WAN). BB
