We don't have a time frame, but we will make it compatible.
Are there any other solution for this? What about other solutions outside of Orion?
Server 2008 has been out for just about 10 months now and you still dont have a solution for this issue. Come on.
Do you have APM? We have an Application Monitor Template for alerting on Windows Event Logs.
Yes I am running APM v2.0. But it's just not the as using the syslog feature. Are there any other tools which will tie into a 2K8 and then let NPM recieve the syslog messages?
We'll be fixing our WELF to work in Windows 2008. I don't know of any other tools, but there may be some.
Any update on this? I dont have APM and Windows 2008 has been out now for...
As Denny noted, we're working on updating the SolarWinds Event Forwarder for Windows to work with Windows 2008.
In the meantime, you might check out this utility to see if it meets your needs: www.intersectalliance.com/.../index.html
Can you give us any real time line? Even like in the next 2, 3, 6 or 12 months would helpful.
With in the next few months we hope to have a beta. If you're interested in participating, please send me a private message and I'll get you on the list.
I'm interested in the event log forwarder, can you provide a link on where I can get it to try it out. I've search on your site and I couldn't find it. thanks!!!
Have you tried to take a look at Windows 2008 event subscriptions... You might be able to accomplish forwarding the events.
