I cant get the color to change on my orion website. I went though admin - themes, I keep changing the color under admin, but it doesnt change the website color. As it is now, its hard to see.
Could you post a screen shot of what you are seeing for clarification?
That looks like version 8.1. Do you have to remain on that particular version?
Cant afford upgrade.
Sorry, I was under the impression that you did upgrade from this post and that your website was still reflecting the old version.
We have two accounts SW29115 SW33626 .
This is for the 33636 account.
So you are wishing to remove the black in the left column?
I really want to darken the all the blue headers. we have them on a projector and they are inpossible to see. The color theme isnt changing the background one bit.
Hotfix 1 for 8.1 addressed something similar to this-
You may try at your own risk.
What are the risks do you know?
Minimal- just keep in mind that you are on a version that is no longer supported. If memory serves me - this was an issue that was addressed with this hotfix-
