I'm considering moving my ORION instance from a 32-bit and leveraging the 8.1 ability to run on 64-bit OS. Does anyone have any experience with this to date? I know its early in the release, but any feedback would be greatly appreciated.
BUMP...
There seems to be a number of folks on the forum who are now running v8.1. Has anyone yet tried v8.1 with the 64-bit version of Win 2003? If so, would you please share your experiences?
Thanks.
I installed 8.1 today on 2003 x64 dual core sun x4100. The install went pretty smooth, with the exception of the SQL. I needed to install the 64 bit application. I am currently monitoring 93 nodes and 849 interfaces. No issues at this point, and it seems to be running fast, at least faster than the old crappy dell server.
Also, I installed Cirrus and the engineers tool set with no issues so far too.
Thanks for the feedback. With regard to your statement about SQL, I assume this is due to the fact that you are running your DB on the same server..? I imagine it wouldn't matter if your DB was housed on a different server..?
Yes, I am running the database on the same box until our new SQL server is ready.
One other thing, I noticed today that almost all of my nodes were taking packet loss. I looked at all the obvious stuff, then determined that it must be something with the Orion server. I rebooted, once it was back up, I couldn't login to the System Manager, I kept getting an error "cannot connect to database" I was able to see the database from Database manager and SQL Management Studio. I re-ran the Config wizard, and all seems ok again. I'm not sure what caused this. I guess this is even more reason to move the SQL database to my new server.
UPDATE:
I think I found the cause of the packet loss I had the other day. I fired up Cirrus on the same server as the Orion (x64) and I saw the packet loss once again. As far as I can tell, the cirrus application is not supported on x64. I uninstalled cirrus, since unistalling I have had a ton of problems.
1. I wasn't able to connect to the local sql database.2. Once I re-ran the config manager, I could not launch map maker, (out-of-memory error)
3. SNMP Trap service will not fire up, I get a Microsoft error 2:
I am in the process of re-installing Orion.
SolarWinds,
Any thoughts on this?
Many issues here-
What permissions do you have for the DB? Is this the new remote SQL you set-up?
Cirrus is not supported on a 64bit OS so it's good that you removed it-
www.solarwinds.net/.../releaseNotes.htm
Not sure about the Map Maker not opening- my guess would be a missing .dll- What is the exact error message?
The Orion reinstall may help- you might want to attempt an Add/Remove - > Repair as well.
I too am about to upgrade my Orion server to a 64bit OS & a separate 64bit MS SQL2005 DB server.
I will also be running a new - second polling engine (actually my old Orion server minus the DB & Webserver), but this is a 32bit server.Will this be compatible, or will I need to upgrade my second polling engine to 64bit as well?
NG,
It should work fine.
While we're discussing 64 bit- BUMP for any updates on the x64 bit version of the Orion Event Log forwarder..
It's something we're considering for the future, but it's not imminent.
We've had Orion 8.1 running on x64 2003 for a few weeks without any major issues.
A couple of days ago the syslog service chewed through about 2GB of ram and really slowed the box down.
Process had to be killed rather than restarted but we've not seen any problems since.
We're using an external SQL server so it's just Orion on the box.
We have had problems running the toolset on the box though as the launcher just crashes on startup.
A
Thanks for the feedback. Also, I don't believe the Toolset is yet supported on x64.
