I am trying to create a custom report that will send out the information about Top 10 Incoming IP's. Is it possible to do that or the Conversation report is as close I will get? I just want to see the Top 10 Incoming IP's.
Sorry - I should have been more complete in my post. Add an IP Adddress Group in NTA Settings -> IP Address Groups and use thes ranges I have. Then use the canned report for top XX IP Address Group in Report Writer.
I'm not sure what you mean by incoming IPs. If you mean public addresses you could create a public addresses IP Address Group and then use a canned top N by address group report.
Yes Public IP's. Where can I create a group for Public IP's I went under NetFlow and then IP Groups I see two private groups there but do not see an option for Public IP's.
Eh this is ridiculous I simply created a group trying to get a group for Public IP's. Not only that did not work but it also messed up my the whole dashboard. Now when I click on the top right hand side "Settings" it just brings me to "Orion Summary Home".
Any ideas on how can I revert back?
That behaviour is typically due to view restrictions. Is there another admin account you can use to see the settings on your account?
There is only one Admin account on it and that is the account I'm using to log in. I think it might have something to do with the browser, because if I use IE it works fine.
Looks like you found it. Which browser was an issue?
Fire Fox 8.0. But my initial issue still remains I need a custom report that will tell me the Top 10 Public IP addresses coming into my network. Almost like the "Conversations" tab but I just want to be able to see the Public IP addresses or is that not possible?
Here is the group I created for that case.
Thank you but where are you going to do that apparently I can't find the same area that is in the screen shot.
I just noticed a small typo in one of Andy's IP ranges. Where he has 172.32.1.1 - 192.16.7.255, the IP End range should be 192.167.255.255.
