Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
sql replication
jhappe
Has anyone attempted merge replication with the SQL backend? I understand the issues it would bring with multiple pollers, but I'm wondering about using it to synch the DB for a hot-standby poller in another geographical site.
Find more posts tagged with
Accepted answers
All comments
BK
In theory it could be done, but you need to have some SQL experince to make it work.
The first problem you would run into would be the Node, Interface, and VolumeIDs. When you add a node to the Orion system, Orion lets the Database Server pick the next Identity number to represent that device. Be default, this "Identity" field, starts at 1 and is incremented each time a device is added to the table. If you let replication merge together two database, you would have overlap between the identity fields in the two Orion database.
The trick would be, before you added any devices to the database, to set the initial value for the Identity field to a high number, like 1,000,000 on the second database, 2,000,000 on the second database, 3,000,000 on the third database, etc This way when you let replication merge the databases together, there would not be any overload in the identity fields.
You would also need to change Identity type from Yes, to Yes, except for replication.
BK
Nobody Special
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
