Any update on the request for Alerts and Advanced Alerts in Netflow for Orion?
I have not heard of any but any updates will be posted here first -
We plan to put NetFlow alerts into a future version. What are some of the alerts you'd like to see?
I still want this, I still need this. What is the update on this issue.
It's not in the next release, but it's still on the roadmap.
Has any progress been made on this requested feature?
I am looking for an alert based on Total Bandwidth in the last 24 hours/Today.
I can do this already with reports, I just need to do it using Alerts so that I can trigger an action.
Alerting is on the roadmap but not date committed today. These use cases are very helpful though in defining the functionallity and getting it assigned to a release.
Andy
Thanks mcbridea,
Is there another way around this? Hooking into the database directly maybe?
If you have Orion APM, you can actually use APM's HTTP user experience monitor to look for certain information on a page of Orion (e.g., is YouTube present) and alert on that.
You can also periodically run SQL Queries on the Orion DB to check for specific info and then use that to alert.
So if you buy a Rolls Royce, you can actually sit inside it and turn on the radio to find out if it's raining outside.
Hmmm...
If you voted for this feature: It's available now as an NTA Release Candidate!
Head over to the NTA Release Candidate forum, and check out the details here: NetFlow Traffic Analyzer Release Candidate
Let us know in that forum what you think, and how you're using this feature to alert on flow traffic in your network!
joer
And this is now available in General Release as NTA version 4.5!
You can check out the Release Notes, download the new release on the Customer Portal, and get all the help they need with the upgrade at the Success Center.
