Anything besides VM updates new in 9.1?
Besides the VMware ESX Server Monitoring -
Custom Views of External Websites - you can designate any website as an additional tab on the Views menu bar in the web console, giving you the ability to bring web content directly into the Orion Web Console.
can you elborate more on how to get an external website as an additional tab on views.
What i want to achive is a page of my internal coded website is displayed inside the master page of Orion Web console.
Does this help?
And the section is documented in the Admin Guide here:
www.solarwinds.com/.../wwhelp.htm
Other NPM 9.1 features are documented here:
And the Release Notes given even more detail:
What about fixes?BB
They're in the Release Notes.
Hi
One thing NOT in the release notes, are the change of node tree view. For some reason you changed the node tree view to show the lowest status of one single node in that container.
Meaning that if you group your nodes in three levels, and one node is either unmanaged, warning or down, the entire top container is having this status.
I have created a case for this, but was given the answer "working as designed" - Well, that might be, but then its poor design. At least it should be an option to choose.
A few other buge / poor design choices (like the missing "select all syslog events") is leaving me with a feeling of a very bad upgrade - and information level from SolarWinds.
Brgds
Jesper Vestergaard
Jesper,
The new behavior is what has been requested by the majority of users. We will update the RNs; leaving it out is an oversight. I'll look into the missing "Select All". If that's replicable, we'll get that fixed.
I agree with Jesper.
I liked it better in the 9.0 version. I would prefer a way to set the severity so that there are visual cues from the map as to what is happening.
We're going to make the rollup configurable in an upcoming SP.
Still no possibility to to span maps over several columns Still no support for "draggable" maps
And what's with the syslog facilites list? I cannot use a single one in the list.
And where on earth is the "Select ALL" button??? Are we supposed to tick 1000 check boxes now, when selecting 1000 messages?
Still no real syslog parser (like the one that is custom made)
Still no possibility to add different custom text to each node.
Still the same gruesome map maker.
IMO, version 9 doesn't deserve a whole version number up, because there is not much difference from 8.5, except slower web performance.
Oh, except for the Universal Device Poller, that is a step in the right direction, but even that looks half finished to me.
Dal,
Can you explain what you mean by "add different custom text to each node"?
Also, I understand that everyone has their own perception, but when considering the evolution of NPM, NCM, and the associated modules as a whole, I think most will agree that Solarwinds products have come a long way in the last couple of years. To me, the introduction of the website for NCM and the underlying changes in V9 of NPM that allowed for the initial integration between performance monitoring and config management is well worth the new v#. The Solarwinds products still have a long way to go to get where I would like to see them, but they have also come a long way in a relatively short period of time without an intolerable increase in price.
