I have the same issue. I have capped the log file to 30GB so we can run the Netflow service until we hit the log file limit. Typically this gives us 30-45 mins. I have a case open and am awaiting help. Let me know if you find out anything and I will do the same.
This KB from microsoft should help you.
"How to stop the transaction log of a SQL Server database from growing unexpectedly" - http://support.microsoft.com/kb/873235.
We have started having this problem this week. Netflow is eating up 30GB of log files in less than 30 mins. This causes Orion to no longer be able to connect to the DB at all. Ihave to have my SQL admins go in and clear up the log and then the DB has to run a repair on itself. I have cut my Netflow dvices back as far as I can right now to 61 interfaces, but I have decent hardware. Dedicated SQL server. 3.0 Ghz processor with 12GB RAM on front end. I have had my SQL developer read the above KB article and his feedback is:
# Back up the transaction log files regularly to delete the inactive transactions in your transaction log.
- We would have to do this every 5 minutes
# Design the transactions to be small.
- Dependent on the application (Orion)
# Make sure that no uncommitted transactions continue to run for an indefinite time.
- Dependent on the applicaiton (Orion)
# Schedule the Update Statistics option to occur daily.
- Doesn't matter as the log fills in 30 mins.
I have sent some of my data to support. I seem to be spending more time babysitting this app lately.
I too am haaving the same problem... Netflow is useless at the moment because of it...
Solarwinds, is there a patch or fix for this issue yet?
We are aware of this issue and are actively working it. No update to share as of now.
any update on a fix for this?
did you get a resolution to your problem yet? I am having the same issue and have had no luck getting it resolved.
Has there been any resolution to this matter. We are having the same problem.
Are you using the latest service packs? If so, can you call Tech Support and get a diagnostics to them? We've addressed this type of issue in our service packs, but if you are up-to-date, then we'd like to investigate what your particular problem is.
Thanks,David
We are up-to-date on all of our service packs, excluding the latest one just released. We will try to that patch and see what happens. I was told that we did not have this problem until we updated our service packs a little over a month ago.
So you're saying that you did not have this problem until you applied NTA 3.1 SP1?
We have done the upgrade for SolarWinds from V9 SP1 to V9 SP4. This is when the problem started. Today we upgraded to V9 SP5. After getting your response, we checked the version of the NTA, it is still at V3.1, no SP. So, we looked on the support site again and found SP2 for the NTA and we are going to apply that. Thanks.
Even after upgrading and applying the service patch, the log file will still eat up about 1 gig a minute of space. The overall actual data files are just about 15 gig, but the log file will continue to grow as much as I will let it. I have limited to 20 gig, where as yesterday it exploded to 34 gig in about 30 minutes.
Hi Everyone, I've been dealing with this issue for a few weeks and been working with Solarwinds support. I was comsuming 65GB of disk space in under 1 hour so I too had to turn off Netflow inorder to use Orion. Last week I worked with one of the developers and what we did was uninstall Netflow, remove all Netflow related database tables, views etc. and end up with a Netflow free database. Then I installed Netflow 3.1 with SP2 and so far its been working for about 4 days now FLAWLESSLY and the ldf file has been really small less then 100MB. So something in the database was causing some sort of lock. I wouldn't mind troubleshooting but I couldn't afford not to use Netflow so I made the recommendation to start from scratch in regards to Netflow. I am very happy we did the necessary changes because now things are working really good.
Hope this helps
Were you running 3.1 SP2 when the problem was happening.
When it started we were not. It started after we upgraded Solarwinds, which did not include the SP2 for Netflow. Even after upgrading Netflow to SP2 the problem remained. We apparently finally got a hold of the developer that remembered fixing yours. He did the same thing to ours and now we do not have the problem anymore.
Is there any current solution to this. We have this issue as well. My log file is growing out of control and we just had a 4 hour outage on both npm and nta as a result. We are currently running nmp 10 and NTA 3.6
We have netflow on 24 devices and about 3 interfaces per device.
Log file grows is mostly caused by a very long transaction. You can determine culprit of it, open SQL management studio and run command.
DBCC OPENTRAN
If there is some transaction for a very log time, you can see log file grows very rapid. After you have it, you can post it here and we can do some tuning.
Also log file grows behavior depends on your [recovery model], do you use recommended simple mode?
We did have it set to simple but in order to try and keep the system running we have changed it to Full and are running tlog backups every 15 min just to keep the log file empty. We have also capped the log at 100g to prevent the corruption issue we had.
I will look for long open transactions.
No open transactions for more than a few seconds that I have seen so far.
