Does, or can, Orion support SQL mirroring? If yes, how is it set up? If no, can it be added as a feature Request?
Hi eanthes--
Here are some posts I found on mirroring. Can they help your specific installation? If not, post back and I'll make sure the PM sees it.
M
Hi Ernie--
I'll let the product manager have a look at this and get back to you.
Thx,
Mirroing SQL is something separate to Orion in the fact that the mirroing is done at the database level. Whether this is using log shipping, DBsnapshots or the various 3rd party apps available.
You dont give your reasons for mirroring, but in most situations mirroring is performed to place an instance of the SQL database at a remote DR location. Whether there is a mirrored, but service disabled, installation of Orion, which in the case of DR failover, the DR Orion will be configured to use the mirrored SQL server. When failing back to the primary site, the database is synchronised back to provide a consistent data collective.
Ernie,
PM me via thwack and we can talk offline regarding some options for you to look into and I can gather more of your requirements.
Hi Brandon
We find ourselves in a similar situation with SQL DB mirroring. We are considering using log shipping instead of native DB mirroring. Have you any recommendations you can share?
Regards
Colly
I was wondering if there was anything new with this? We would like to use mirroring here with our Solarwinds products as well.
Our setup has two physical SQL servers at two different locations that mirror databases between the two. Our Orion install is a virtual server that is protected with SRM between those two locations. If we have to failover to the DR site, it would be nice if the solarwinds software could see that it cannot talk to the primary database and talk to the failoverpartner instead automatically.
I'm curious, too, you get any responses on this point? I'm kind of sad the product manager took things offline in the previous posting.
Don't be sad, I am always paying attention
Check this doc out we put together and see if it helps.
Thanks for the speedy reply! I read through that doc and it appears that the MSSQL mirroring isn't supported (without the Failover Engine product, at least).
Taking a different tack, is there any way to specify via ODBC which database Orion NPM uses or is choosing the database only done via the database manager?
Hi
As I understand Orion NPM does not support sql-mirroring but:
1: Does the failover component support that?2: Can I edit the sql connection string manually? (Becouse the sql .net data provider supports it by using the "FAILOVER PARTNER=[MyMirrorServerName]")2.1: If I can, where is it?
/Thomas
