I uninstalled NMP from a windows 2012 server and now it will not reinstall. Does anyone knows what I am doing wrong?
Please assist!
You didn't mention any errors or specific issues.
Here is a generic uninstall procedure: http://www.solarwinds.com/documentation/en/flarehelp/npm/content/npm-uninstalling-npm-sw1446.htm
This is a general uninstall procedure, and it may differ slightly from version to version.
SolarWinds recommends to use this procedure when installing daily builds for testing.
regedit
HKEY_LOCAL_MACHINE > Software
C:\Program Files (x86)\SolarWinds
C:\Program Files (x86)\Common Files\SolarWinds
C:\inetpub\SolarWinds
C:\ProgramData\Solarwinds
C:\ProgramData\SolarWindsAgentInstall
Thanks for your prompt response d09h, I did some of your instructions before and also some folders wont delete.
When I start installation, the yellow starting installation window pops up and then disappeared....that's it! nothing happens after and nothing is installed.
I am thinking if this is windows 2012 thing......the last one I used was 2003 server...this is really new interface and a few new features for me.....
still at it.....
I think it would be helpful to post any error messages you can find.
None!!! no error message......installation starting window just goes away and that's it...
I would open a support ticket but you can also look at the OrionInstaller.log located in the following directory.
I had faced similar issue in my lab setup... it wasnt listing any errors like u mentioned... i tried to install it multiple times and ended up having an error stating license is corrupted. in my case since it was lab setup i just built another server and got it started....
Ok....I rebuilt the server and still got the same thing, but now I got to the log and here is what I got.....
[13: :15:921] ----------------------------
[13: :15:921] OrionInstaller.BootStrapper Starting.
[13: :17:437] Checking Windows Versions
[13: :17:437] MSMQ check.
[13: :17:437] MSMQ already installed
[13: :17:437] Starting the following services: SWCollectorService;SWInfoServiceSvc;SWInfoServiceSvcV3
[13: :17:437] .Net 4.6.2 detected.
[13: :17:437] Starting "C:\Users\ADMINI~1\AppData\Local\Temp\SolarWindsOrionSetup20170829130014\OrionInstaller.exe" from "" with command line of "OrionInstaller.exe -INSTALLEREXE="C:\Users\ADMINI~1\DOWNLO~1\NPM-12~1.EXE" -SESSIONID=5C69DDB9-5199-41C0-BF31-A4FFFDA1DEF0".
[13: :17:437] Process started. PID = -1 GLE = 2
[13: :22:869] OrionInstaller.BootStrapper Stopping.
Any ideas?
did u use the old installer setup after re-building the server?
now I went into the temp folder to try run the installer directly...here is what I got
System.IO.FileNotFoundException: Could not find file 'C:\Users\Administrator\AppData\Local\Temp\SWOrionSetup201708291311\InstallManifest.config'.
File name: 'C:\Users\Administrator\AppData\Local\Temp\SWOrionSetup201708291311\InstallManifest.config'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials, IWebProxy proxy, RequestCachePolicy cachePolicy)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReaderImpl.FinishInitUriString()
at System.Xml.XmlTextReaderImpl..ctor(String uriStr, XmlReaderSettings settings, XmlParserContext context, XmlResolver uriResolver)
at System.Xml.XmlReaderSettings.CreateReader(String inputUri, XmlParserContext inputContext)
at System.Xml.XmlReader.Create(String inputUri, XmlReaderSettings settings, XmlParserContext inputContext)
at System.Xml.Linq.XDocument.Load(String uri, LoadOptions options)
at OrionInstaller.Program.CreateWizard(String[] args)
i m not that much experienced to help on these kind of errors.
By old installer setup i meant- Sometimes the setup file would have got corrupted or a prob with registry.. so i was mentioning about downloading fresh evaluation setup..
Maybe you can wait for someone to assist on the above errors...
Sure, I did download a fresh copy but no joy.
Do you have NCM?
yes i do.....but not installed yet.
You uninstall Node.js and NPM the same as you would most Windows software:
modem wifi password
Now, here is what is going on....when the installation start extracting files into the temp folder, I see it populate the folder with installation files and when the installation stops all the files disappeared!! I tried to copy some files and installed NPM, but I get an error while trying to run NPM configuration wizard....
* No valid package combination was found for your system
I believe this is because I copied the installation files manually....how do I fix this?
