How do get the Blockers Tab to show up in my Database Performance Analyzer Tool For Oracle Databases?
These cases were both solved by the following. We are adding a KB with the steps but, posting here for anyone landing on the thread.
There is an advanced option that by default disables blocking information for Oracle RAC systems from being collected. To Turn this on, go to:
Options->Administration->Advanced Options->DB Instance Options
Select the RAC instance that you want to see blocking data for
Select the Support Option check box
Go to the following option (ORACLE_QUERY_LOCK_INFO_DISABLE_ON_RAC)
Change value to 'false'
Restart Monitor
You have to be drilled into an hour timeframe. Otherwise, there's a LOT of data to parse through - our attempt to be efficient and as quick as possible.
Thanks mandevil. Let's say I'm already drilled down from database, to day, to timeframe, to SQL....I still don't see the blockers tab. And to be clearer, I am trying to looking at blocking from 4 days ago. So, I still don't see any blocking information displayed by DPA.....do I need to drill down even more?
You should not have to. Can you describe the instance/environment you are monitoring? Oracle/SQL Server/MySQL/Sybase/DB2? What version? If Oracle, is it RAC?
All of our databases that are registered with DPA are Oracle RAC. Versions for the most part are 11.2.0.3 or 11.2.0.4.
Can you open a support case? There are specific options that you have to enable to get the blocking information. We'll want to make sure everything is enabled for your monitoring...
I'll do that. Thank you again for responding and your help.
mandevil, I haven't opened a Support Case before. Can you guide me through the necessary steps?
Do you have access to your customer portal? If you do, you should be able to open a case directly from there for DPA (under the support tab).
If you don't have access, you can send an email to customerservice@solarwinds.com and request access by providing your SWID.
Perhaps reference this thread in the case with a link so that when we find why this is not showing up for you we can post back the answer here for others.
I do have a support case open for this issue. case # 1015993 I have emailed in the case a few times and called the number that is listed and haven't heard back. Please do call in to the support line Phone: 866.530.8040, Option 3 for this case if you still need help.
FYI, we're having the same issue; Oracle 11.2.0.4 RAC Standard Edition running the current DPA RC. We see the tab with our non-RAC databases, just not on the RAC instances. I'll open a case as well but wanted to make note here.
