Good Afternoon,
I have created a report in hopes of locating workstations with a particular executable residng on the machine. However, I am receiving no results. I have configured the inventory to include both Files and Directories by placing the appropriate check mark on the Datasource configuration tab. Is this not the appropriate or only measure required? Is this data not collected? When creating the report I am able to select the File(Name) and enter the file that I am looking for. I would assume this means that the data is being collected.
Thank you.
Hi russo1203,
There are a couple of things that may be happening here.
1. In the Inventory Configuration Editor, after you clicked to collect file and directory information on the Datasource Configuration tab, did you click on the "File, Directory and Registry Datasource Configuration" tab to specify which files and directories to include? It is the box near the middle of that tab that references "file system object".
2. If you did specify them there and successfully saved your new Inventory Configuration template, please note that existing scheduled Inventory tasks will cannot use the new Inventory Template. You will need to create a new Inventory task and select "Inventory - include specific datasources", then "Select a pre-defined inventory configuration template", choose your new template, then scheduled it to run as you wish.
-Kelly
Kelly,
I did not add any files or directories on this tab of the Inventory Configuration. As someone that previously utilized SMS 2003, I am used to the .exe information being included in the inventory. I did search and find another post mentioning the use of wildcards is not supported.
Would you say that the functionality is such that one would need to create a special inventory to run and include only the .exe that I am looking for, or is there a way to collect all .exe information and store in the database? Thank you for your time and assistance with this matter.
No, there is not currently a way to gather all .exe information. I'll submit your query (allow wildcards so as to allow gathering information on all files of a particular type during inventory) as a Feature Request to development for review.
Whether to create a special inventory task is a matther of opinion really. If looking for a particular .exe is something you routinely do and you need it to be accurate to the last time a scheduled inventory is run then I would modify an Inventory Configuration template and create new scheduled Inventory tasks using that template to replace my old scheduled tasks.
If it's more of an as-needed activity, or if the particular file in question that you want to look for may change often, I would likely just do a one-off inventory task targeted at the machines you are interested in when needed.
So 2 years later, i am revisiting this. I have created a new inventory seraching for a file. My question is how do I report on this information? Thanks.
Russo1203:
Could you let me know the "why" you are doing this? I can see a few reasons for this, but was wondering what drove you needing this.
KMSigma
We are looking for workstations that have Cygwin installed, i.e. C:\Cygwin64\bin\bash.exe. Any assistance is appriciated.
Have you tried just a simple Installed Programs report? If you've already done a WMI Inventory, then collecting information about installed programs is on by default.
Run the Installed Programs and Feature Basic report in the Installed Programs and Features report category, and filter as necessary.
I think that part of the burn here is that older versions of Cygwin (if I'm remembering right) can just be downloaded as a ZIP and dropped in a file location.
Hmm.. that would complicate things a lot.
That also means there's no guarantee as to the actual installation pathname.
One would almost have to do a DIR /s /p | FIND /i "bash.exe" from the ROOT of every drive in that case.
Were that the case, I'd say put that in a script and run it across the network overnight
For Each $machine in (list of $machines)
ECHO $machine >> BashTestOut.txt
DIR /s /p \\$machine\c$ | FIND /i "bash.exe" >> BashTestOut.txt
Or you could get a bit more fancy and use PSEXEC to run the DIR on the remote machine and then just copy back the output file across the network
ECHO $machine >> BashTestOutMaster.txt
PSEXEC \\$machine DIR /s /p C: | FIND /i "bash.exe" >> BashTestOut.txt
COPY \\$machine\c$\BashTestOut.txt >> BashTestOutMaster.txt
One could also do that in PowerShell too. :-)
