I made an APM Application´s alert.
If application is critical or down , I´ll receive an alert.
My question: If one component goes down, will I receive an alert ?
(This application haves 3 components).
Nothing has changed yet.
We are tracking this as Feature Request now in our internal tracking system (case 69428)
Hi contracer,
This depends on your Status Roll-up Mode setting (Settings > Web Console Settings).
If you set roll-up mode to "Show Worst Status" then Applications get a Down status if 1 or more member component monitors are down. In this case, your alert would become active for a single monitor being down.
If you set roll-up to mode to "Mixed Status Shows Warning" then Applications get a Down status only if all member component monitors are down. In this case, your alert would not become active for a single monitor being down.
Contracer,
I have to correct my answer. One of our devs pointed out to me that the APM application status roll-up is hard-coded to worst mode, and cannot be changed.
The status of an application is determined by these rules (in order of priority)
1. If app has a down component, application status is down.
2. If app has an unknown component, application status is unknown.
3. If app has a critical component, application status is critical.
4. If app has a warning component, application status is warning.
5. Otherwise, application status is up.
So if one component is down, the application it belongs to will show down, and your alert will trigger as you expect.
Please forgive me if I caused any confusion with my previous, incorrect answer.
Has this changed since this was posted? We have a need to show an applicaton in a degraded status if a single component is down.
Steve Miller
Any update on the feature request (case 69428)? We also would like to have application show degraded status if a single component is down.
Nothing new to report as of yet. We do however have a new SAM 5.5 Beta available that's packed full of new features.
Anything new yet? I'm still trying to do this.
Maybe it will be in the SAM 6.5 beta?
I'm also trying to accomplish this, so we don't say that all of Appinsight for Exchange is "Down", when just a component that we want to monitor goes down. I'm surprised this feature request has been around for so long... Any update you guys can share?
Yeah, the problem we currently have is a bunch of our AppInsight for Exchange monitors are in an Undefined/Unknown status because a few items within them are Unknown. Now whenever a component inside of them goes into a Critical status the App monitor itself remains in the Undefined status, meaning if we want to accurately alert on our AppInsight for Exchange components we can only do it at the component level. I wish there was better control as to how we'd like to handle this. I also wish that Undefined status didn't trump Critical status. That doesn't seem right...
