Unable to use the SWIS API for any kind of queries.
Getting a connection reset error before getting results of the queries.
This used to work fine , but now on a browser it shows a certificate warning and then shows a page cannot be displayed.On continuous refreshes of the browser , After 5 minutes, prompts for the username and password and starts showing results.
Having no issues with website. Just this SWIS response are delayed for some reason.
Here is a curl output
curl -k -v -u testuser:testuser https://<SOLARWINDS_SERVER_IP>:17778/Solarwinds/InformationService/v3/json/Query?query=SELECT TOP 1 NodeID, Caption FROM Orion.Nodes* TCP_NODELAY set* Connected to <SOLARWINDS_SERVER_IP> port 17778 (#0)* schannel: SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778 (step 1/3)* schannel: disabled server certificate revocation checks* schannel: verifyhost setting prevents Schannel from comparing the supplied target name with the subject names in server certificates.* schannel: sending initial handshake data: sending 178 bytes...* schannel: sent initial handshake data: sent 178 bytes* schannel: SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778 (step 2/3)* schannel: failed to receive handshake, need more data* schannel: SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778 (step 2/3)* schannel: encrypted data got 913* schannel: encrypted data buffer: offset 913 length 4096* schannel: sending next handshake data: sending 358 bytes...* schannel: SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778 (step 2/3)* schannel: encrypted data got 91* schannel: encrypted data buffer: offset 91 length 4096* schannel: SSL/TLS handshake complete* schannel: SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778 (step 3/3)* schannel: stored credential handle in session cache* Server auth using Basic with user 'testuser'> GET /Solarwinds/InformationService/v3/json/Query?query=SELECT%20TOP%201%20NodeID,%20Caption%20FROM%20Orion.Nodes HTTP/1.1> Host: <SOLARWINDS_SERVER_IP>:17778> Authorization: Basic dGVzdHVzZXI6dGVzdHVzZXI=> User-Agent: curl/7.55.1> Accept: */*>* schannel: client wants to read 102400 bytes* schannel: encdata_buffer resized 103424* schannel: encrypted data buffer: offset 0 length 103424* schannel: Curl_read_plain returned CURLE_RECV_ERROR* schannel: encrypted data buffer: offset 0 length 103424* schannel: encrypted data buffer: offset 0 length 103424* schannel: decrypted data buffer: offset 0 length 4096* schannel: schannel_recv cleanup* Closing connection 0* schannel: shutting down SSL/TLS connection with <SOLARWINDS_SERVER_IP> port 17778* Send failure: Connection was reset* schannel: failed to send close msg: Failed sending data to the peer (bytes written: -1)* schannel: clear security context handlecurl: (56) Send failure: Connection was reset
I'd follow the troubleshooting recommendations from this thread: https://thwack.solarwinds.com/t5/Discussions/Connection-to-REST-port-getting-reset/m-p/75708
I did a netstat -an | findstr "17778" and got 1106 rows of ESTABLISHED connections.
We have only around 90 Solarwinds agents pointing to this server
There is related discussion for this particular case on a separate thread at https://thwack.solarwinds.com/t5/Discussions/slow-response-from-SWIS-API/m-p/590329. It seems like testing the network connection with tools like NetPath, Traceroute NG, or Wireshark might be the next step.
