Software
I am trying to create a Software Inventory report based on a Group of PC's but don't seem able to add a filter for this.
Can anyone point me in the right direction
Many Thanks
Mark
Conditions can be added to filter the report by going to [Settings -> Manage Reports -> Select "Software Inventory Report" -> Click "Edit Report" -> and editing the "SoftwareDataSet"] as pictured below.
Thanks aLTeReGo...
However I'm not sure how this will work. I need to add a filter somewhere for the Group, when I do this I get an error message, see below as obviously this information doesn't exists in the DB.
I can't find a Node property which identifies it is in a Group and hence add a filter..
Any other suggestions would be welcomed
You would not use groups, but rather Custom Properties to categorize and classify these devices for filtering within the report.
I have added a description into the department field for the node and used this as the filter; report is now working as expected.
Many thanks for you assistance
Kind Regards
Mark Bairstow
Here to Help IT Ltd
Mob: 0771 3245 725
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail, together with any copies, from your system. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden. This Message is attributed to the sender and may not necessarily reflect the views of Here to Help IT Ltd, its subsidiaries or associates. This transmission has been issued by Here to Help IT Ltd, registered office 61 Cedar Close, Essex IG9 6EJ. Registered in England.
How are you forming your report to get a list of applications and install count? When I create a query to list all workstations, select the inventory info etc all I get is a list of all the software installed on them?
I don't see how to get an overall list of software with installation count. I would have thought there would have been some basic out of the box reports for standard things like this which can then be copied an edited as required?
Hi hthit, I installed 11.0.1 yesterday but I don't see that report listed anyway even when I do a search unless I'm being a complete fool. Could you send a screenshot of what you see please?
Hi Lufffunk,
See below,
I have modified the report that came with SW and now have 2 with different filters applied.
This is a ample output from one of the reports.
Hope this helps
Right I think I have a problem then as the only reports that show up for me are the two custom ones I've been playing with! Having seen your screenshot and looked at the online Demo it seems there should be loads there!
Certainly looks like it.
Have you checked in the Admin section under Manage Report to see if they are in there? Also presume you are set-up as an administrator in Solawrinds.
No they don't show up there - good to know I'm not going mental. I will log a ticket... yes full admin.
