Hi, could someone please let me know if the Engineers Toolset (I am using Ver 10) supports sFlow?
I ask because I am going to a site that has HP Procurve switches and we would like to get sFlow stats from the switches.
The Engineer's Toolset Realtime Netflow Analyzer supports Netflow v1 & Netflow v5 traffic. You can try a free evaluation version of our Orion Netflow Trafix Analyzer. It supports sFlow.
Steve
Thanks Steve
So to get the s-Flow i would need a network connection from our Orion Server (with NTA) as the Engineers Toolkit is just going to give me a 1 hour view of Netflow. (Not sFlow)
Regards
Paul
Paul,
Yes, to view your sFlow data you will need access to your Orion Web Console. The Toolset will only be able to display NetFlow data.
We've added this to our knowledge base here http://knowledgebase.solarwinds.com/kb/questions/2053/.
Hello, anyone could you teach me about support versions of sFlow?
I can't find out support versions's sFlow.
I'd like to see Extreme sFlow.
with my best regards.
sFlow is not supported in Engineer's toolset.
Peter
Hello peter,
Thank you for your help. I refer following FAQ.
http://www.solarwinds.com/engineers-toolset/resources.aspx
Q: Can Engineer’s Toolset monitor NetFlow?
A: Yes, the NetFlow Real-time tool captures and analyzes Cisco NetFlow 5 & 9, JFlow, AppFlow, and sflow
Isn't sFlow supported in engineer's toolset?
If I can see sFlow by engineer's toolset, I'd like to know about sFlow's version.
Sorry again.
best regards.
Hello,
engineering checked with the lab device and the result is negative - toolset doesn't support the sflow. I apologize for the confusion created by the description on the product pages and thank you very much for catching that, as it needs to be fixed.
Hello Peter,
Thank you for your help. I appreciate for your tests very much. My customer use freeware for checking IP and mac address.
I'd like to use "Print Screen" of Engineers Toolset and KIWI syslog server for my presentation and selling. Can I use these "Print Screen"?
masashi
Hi Masashi,
I'm not sure I understand the question with the print-screen. Can you please be more specific or prefer a quick call?
How to Capture Screen Shots in Windows Using the Print Screen Key
https://support.microsoft.com/en-us/kb/173884
Can I use capture screen of Engineer's Tools set? I'd like to make presentation-file(pptx) for sales.
In Japan, there is many sales engineer. If there are many product picture, presentation is easy to understand.
Sorry my English.
regards.
OK, now i understand! Yes, you can share the details like that
Have a nice day
