I just installed Newflow and in looking at the traffic, I see that there is some "unmonitored traffic" Can someome tell me what the unmonitored traffic is?
Gary
By default, there are a large number of ports that NTA monitors; however, it does not monitor all ports by default to conserve space. If you have a lot of unmonitored traffic, you might want to add additional ports. You can also run a SQL query to monitor all ports.
is there a way to group a number of ports together to be listed as one application ? ( i.e voice etc )
Cheers
I would like to know about this as well... I made another post but still no responses yet. Specifically I want to set a port range for VoIP... others I can add by hand if needed...
This feature is scheduled for the next release of NTA.
Great news...I assume you mean v3.0 ?
Correct!! This is a feature we are planning for the next release. I recommend signing up for the NetFlow Beta at which is currently underway. The next beta round, slated to begin in a few weeks, will enable you to test out this feature.
Hello...I'm a little new to using NetFlow. I am also seeing a lot of 'unmonitored traffic' on some of our interfaces. Currently we're testing this out before we purchase it. I have gone through and checked all the ports that we would think are being used. All of the major ports used by Microsoft as well. I still have a lot of 'unmonitored' traffic though. Any recommendations for determining what this traffic may be so I can check the right ports?
Scotto
how can I view which are the port numbers that are being "unmonitored"? Can a list be generated?
Under the NTA Settings, in the "Manage Applications and Service Ports" view, the left pane of the page entitled "Views", has a view for "Disabled Applications". Click that.
But after thinking about it, you aren't probably looking for that, are you? Are you looking for this list plus a list of ports that aren't associated with any application?
Thank You for yor response.
I did what you said and tried enabling "monitor All ports" Although I still get a lot of Unmonitored traffic.
Do I have to enable them one by one?
As for the list , an SQL query would be helpful of all the Unmonitord traffic , although this may return -1 for the ports, instead of telling me the actual port number.
Thank You again
