Anything besides VM updates new in 9.1?
Besides the VMware ESX Server Monitoring -
Custom Views of External Websites - you can designate any website as an additional tab on the Views menu bar in the web console, giving you the ability to bring web content directly into the Orion Web Console.
can you elborate more on how to get an external website as an additional tab on views.
What i want to achive is a page of my internal coded website is displayed inside the master page of Orion Web console.
Does this help?
And the section is documented in the Admin Guide here:
www.solarwinds.com/.../wwhelp.htm
Other NPM 9.1 features are documented here:
And the Release Notes given even more detail:
What about fixes?BB
They're in the Release Notes.
Hi
One thing NOT in the release notes, are the change of node tree view. For some reason you changed the node tree view to show the lowest status of one single node in that container.
Meaning that if you group your nodes in three levels, and one node is either unmanaged, warning or down, the entire top container is having this status.
I have created a case for this, but was given the answer "working as designed" - Well, that might be, but then its poor design. At least it should be an option to choose.
A few other buge / poor design choices (like the missing "select all syslog events") is leaving me with a feeling of a very bad upgrade - and information level from SolarWinds.
Brgds
Jesper Vestergaard
Jesper,
The new behavior is what has been requested by the majority of users. We will update the RNs; leaving it out is an oversight. I'll look into the missing "Select All". If that's replicable, we'll get that fixed.
