Our Internet Cisco router is showing no interface errors, but Orion is showing interface transmit discard errors in the thousands. Shouldn't the counts match?
ok So in doing the show policy map interface command I am seeing the Bandwidth policies that are in place, but its not showing any dropped. I am seeing where it is showing exceded stats, and I would hope that it was dropping those, but not sure on that.
After the exceeded stats it should say actions; and tell you what they are.
police: rate 30 % rate 460500 bps, burst 14390 bytes, peak-burst 1500 bytes conformed 2566350 packets, 2417555326 bytes; actions: transmit exceeded 3807 packets, 3150229 bytes; actions: drop violated 393523 packets, 584415562 bytes; actions: drop
Out discards are not errors, strictly speaking. Rather, they're an indication that the device on transmit was unable to enqueue an outbound frame (and, hence, discarded it.) It is an indication of bandwidth congestion. Transmit errors are enqueued or transmitted frames that got borked on the way out.
Also, note that average utilization is a bad indicator of peak utilization. You can have a very low average utilization (depending upon polling interval, general traffic usage of an interface, etc) but still have out discards if there's a spike of traffic greater than link speed + egress buffer
Will
are the interfaces trunk lines? prune only neccassry vlans on the wire. some switches cannot handle 10 20 vlans. stp has to designate 1000 vmacs for every vlan. had same issue with discards errors
ok so I have a similar Issue. Our primary internet Line, a 100Mb MPLS connection on a cisco 3825, is generating about 2000 discards per hour. No errors. I can't see any reason why it is doing this. Anyone?
You know what, cancel that. I just remembered we had setup 2 policing policies on that router. It just occured to me that those are most likely the source of the discards.
ok Cancel that Cancel, We turned off the two servers that we were policing and it is still generating the Discards. Now it's getting bad enough that while regular browsing isn't affected very often, large downloads, or sustained downloads stall out.
Packets dropped outbound due to QoS are also part of Output Drops(CISCO).
2000 an hour on 100Mbps and out of a large amount of packets shouldn't be hurting anything. Show policy-map interface [interface name with QoS policy) and look for packet drops from your policy f any.
If the input speed of other interfaces on the router is higher than the 100Mbps MPLS than you may be queuing up packets to fast to go out the link. Happens all the time when 100Mbps input feeds a DS3 out. If that's the case you need to QoS important traffic so most of the drops become less important traffic, drop the input interface speeds, or upgrade the MPLS.
Orion transmit discards correspond to output drops and transmit errors correspond to output errors, both from the show interface command
ok so As it turns out, there was another qos policy put in place that I hadn't noticed before. This would explain why when I killed the two servers I had policing setup for, it was still getting discards. So after rebooting the router and the firewall everything is running fine. no more stall-outs.
