Is Solarwinds planing to add this feature to the Report Writer? For us not SQL Query Pro's this would be a well used option.
Please elaborate on what you're looking for, and I can add it to the queue. I need to know the scenario, the problem you're trying to solve. That's more useful and likely to get in than a flat description of a feature.
This was out lined in many threads under the title of Outage Duration in the Reports section. Also this would be very helpfull when you select a date range.
SELECTStartTime.EventTime,Nodes.Caption,Nodes.Location,StartTime.Message,DATEDIFF(Mi, StartTime.EventTime,(SELECT TOP 1EventTimeFROM Events AS EndtimeWHERE EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5AND EndTime.NetObjectType = 'N'AND EndTime.NetworkNode = StartTime.NetworkNodeORDER BY EndTime.EventTime)) AS OutageDurationInMinutesFROM Events StartTime INNER JOIN Nodes ON StartTime.NetworkNode = Nodes.NodeIDWHERE (StartTime.EventType = 1) AND (StartTime.NetObjectType = 'N')ORDER BY StartTime.EventTime DESC
What I'm looking for is the business problem you're trying to solve.
I have been asked by management to provide a report that shows the outage duration of the node verus just a report that shows the up and down events. This would help in providing SLA reports to the management team. At this time I am having to due the calculations by hand within Excel.
Jim
Thanks. That's exactly what I needed. I'll add it to the queue.
Hello,
I am using the following SQL statement to pull a monthly report outage.
SELECT StartTime.EventTime, Nodes.Caption, Nodes.Location, StartTime.Message, DATEDIFF(Mi, StartTime.EventTime, (SELECT TOP 1 EventTime FROM Events AS Endtime WHERE EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5 AND EndTime.NetObjectType = 'N' AND EndTime.NetworkNode = StartTime.NetworkNode ORDER BY EndTime.EventTime)) AS OutageDurationInMinutesFROM Events StartTime INNER JOIN Nodes ON StartTime.NetworkNode = Nodes.NodeIDWHERE (StartTime.EventType = 1) AND (StartTime.NetObjectType = 'N') ANDeventtime between dateadd(month, -1, getdate()) and getdate()ORDER BY Nodes.Caption ASC
My manager as asked if there is a way to consolidate the outage times? Meaning, instead of a daily status, can we just show one line for each site with the total outage time for that month? I am not a SQL guru so I am not sure how to modify this script to output this kind of data. Any help is greatly appreciated.
Troy
I'm not a SQL guru either. But I know that there are folks out in the community whose SQL-fu is strong. Can we get a little love here?
For you SQL Ninjas, is there a way to take the downtime report that's listed above (which we are using) and introduce an exclusion for time of day? I am trying to figure out what our downtime is, but only care about it if it's during business hours.
Maybe a quick and dirty way to get this is the following report from content exchange:
At least as a starting point if you are not a DBA :}
One thing to consider on outage reports like this, is that this records only when the entire node goes down. Of more interest to most execs are WAN outages. Since many nodes actually have multiple paths, simply looking at the node outage won't be accurate. In this instance it takes looking at a specific interface outage. Now having said that I'm not an SQL guru either. What I've done to ID WAN interfaces in my network is to create a custom interface resource called WAN with a yes/no selection. So what I would be looking for is a report writer resource that would let me show all the down events and total duration of that down event for an interface with a custom resource of WAN = yes over a 30 day period. Any one, Any one
I'm no SQL guru either, but i do understand the query... We have adopted the query and made it work for us. I have set this up several different ways and have settled on one that works best for me. I will describe the way we use it...
I have set up a dts package to handle the outage reporting process. It creates a table and puts all of the outages that meet your criteria into it. Then it removes the entries that do not meet the time frame that we use for outage reporting. I scheduled this query run every 30 minutes so there is always 7 day worth of up-to-date outage events residing in the table ready to be queried(i do this so i dont have to chase down a bunch of root causes at the end of the report week). At this point you could use something like SQL reporting services to genertate your outage report or you could use Excel to grab the data from the outage table. We use Excel for this as we still have to assign a root cause for all outages that meet the criteria. As soon as we settle on a new help desk system i will be looking to link to the tables that hold root cause information so that we can automate the outage reporting entirely on the backend.
the query is commented to make it eaiser to read.
--*************************--Outage Reporting Process--*************************
--Disable returned output SET NOCOUNT ON
--Delete Old/Stale DataDROP TABLE Outage
--Gather up all outage data for the last 7 days and load it into the Outage TableSELECT StartTime.EventTime AS EventTime, Nodes.Caption AS Caption, --custom propertyNodes.Company AS Company, --custom propertyNodes.Production AS Production, --custom propertyNodes.Report AS Report, --custom propertyNodes.IP_Address AS IP_Address,DATEDIFF(Mi, StartTime.EventTime, (SELECT TOP 1 EventTime FROM Events AS Endtime WHERE EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5 AND EndTime.NetObjectType = 'N' AND EndTime.NetworkNode = StartTime.NetworkNode ORDER BY EndTime.EventTime)) AS OutageDurationInMinutes INTO OutageFROM Events StartTime INNER JOIN Nodes ON StartTime.NetworkNode = Nodes.NodeID WHERE (StartTime.EventType = 1)AND (StartTime.NetObjectType = 'N')AND EventTime BETWEEN DATEADD(DAY, -7, GETDATE()) AND GETDATE()AND (Nodes.Production = 1)AND (Nodes.Report = 1)AND NOT (Nodes.UnManaged = 1)ORDER BY 1 ASC
--Clean out entries that do not meet the time reporting criteria, we report outages between 6am and 10pm that last more than 5 minutes
DELETE FROM OutageWHERE (OutageDurationInMinutes <=5)OR (CONVERT(CHAR(2), EventTime, 114) BETWEEN 22 AND 24)OR (CONVERT(CHAR(2), EventTime, 114) BETWEEN 00 AND 05)
