I have been reading in the forums about using rules to send out alerts. Does anyone know how to do that?
I am trying to just get notified when a web servers IIS services gets restarted..
Any clues anyone?
Mark,
I dont see those defaults. Is there a way of getting them back?
You will need to have the Application Monitor module installed and then you will see the option- sorry, I was not clear.
thats the weird thing!! i do have application monitor installed but no defaults.. i just upgraded 2 weeks ago from v7.8....
Could you tell me the steps you are doing? also have you ran the Config. wiz since the App Mon. install>? ran a baseline? or used the App Mon. at all?
Well im going into my System Manager => Alerts => Configure Advance Alerts. And i dont see any default alerting to do with Applications..
The last time i ran the config wizard was when i set it up 3weeks ago..
Yes i did run a baseline and i am using the app mon for my web and sql servers...
try this-
Config. Adv. Alert ->New->Trigeer Condition- pull down Type of Property to Monitor-
It should be there- not sure why its not-
This is what i have for a test alert.. tell me if i am doing it right..
Node Name is equal to ABCD123
Application name is equal to Internet Information Server
Application Status has changed.
thanks for your time mark...
