NCM Supports Huawei & Netscreen vendor ??
Yann, is correct. However, as he noted, we'd be happy to work with you on creating a template. If the Huawei devices provide a CLI and store text-based configs, it is highly likely that we can support them with minimal effort.
If you can post the exact series of commands that must be entered (from SSH or Telnet) to login to the Huawei device and show the running and startup configs, we can get started on the template.
For example, for a Cisco IOS devices the series of commands would be:
There is no device default template for Huawei devices in NCM, so I am not sure if NCM will be able to retrieve a configuration from a such device. I did not find anything in the content exchange zone either.
Do you have an eval or a full version of NCM installed and a Huawei device available to try to download the configuration from it?
If yes, then I can guide you to create the Device Template that NCM use to know which commands to send. Not sure if we will be successful, but it is worth to try.
Concerning the Juniper NetScreen models, a Device Template is automatically installed with NCM, so you should not have any issues downloading from that type of equipment.
Yann
Thank's a lot
i'll be back once the necessary information are available
Hello
Was this ever resolved?
I have a case open right now with Solarwinds Support team for this very thing.
Here is what you requested all those years ago
*******************capture below************************Login authentication
Username:usernamePassword:passwordInfo: The max number of VTY users is 5, and the number of current VTY users on line is 1.<Quidway>screen-length 0 temporary<Quidway>system-viewEnter system view, return user view with Ctrl+Z.[Quidway]display saved-configuration[Quidway]display current-configuration
*******************capture above************************
Hope you or anyone can help
Regards
Chris
Hi Chris--
Would you mind posting your ticket case #? Please keep us updated with your progress.
Thank you,DH
Hello Danielle
My SR is = 284575.
Not having much luck with these devices. It is a Huawei Quidway S2326TP-PWR-EI.
To date we experience the same issue on all the Huawei devices we have. S9306 etc.
Thankyou to the person above who also posted their device template. I will try it out and report back to all.
Kind Regards
Hi all
I have just tried this out. The template looks good but still no luck.
Below is the section of the session-trace which shows it going pear shaped.
It seems to not recognise the new prompt after system-view is entered.
[2011-Nov-29 9:20:39 AM] <-- system-view[2011-Nov-29 9:20:39 AM] Process Line = <>[2011-Nov-29 9:20:39 AM] --->system-v[2011-Nov-29 9:20:39 AM] Start check prompt for menu-based device[2011-Nov-29 9:20:39 AM] Process Line = <system-v>[2011-Nov-29 9:20:39 AM] Fuzzy match detector start detecting prompt. String1=system-v String2=<quidway>[2011-Nov-29 9:20:39 AM] Pushing back: <system-v>[2011-Nov-29 9:20:39 AM] mPrompt is : <<Quidway>>[2011-Nov-29 9:20:39 AM] --->iew[2011-Nov-29 9:20:39 AM] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<>>>[2011-Nov-29 9:20:39 AM] Start detecting command echo in echo buffer...[2011-Nov-29 9:20:39 AM] Start check prompt for menu-based device[2011-Nov-29 9:20:39 AM] Process Line = <system-view>[2011-Nov-29 9:20:39 AM] Fuzzy match detector start detecting prompt. String1=system-view String2=<quidway>[2011-Nov-29 9:20:39 AM] Pushing back: <system-view>[2011-Nov-29 9:20:39 AM] mPrompt is : <<Quidway>>[2011-Nov-29 9:20:39 AM] --> [2011-Nov-29 9:20:39 AM] --> Enter system view, return user view with Ctrl+Z.[2011-Nov-29 9:20:39 AM] --> [Quidway][2011-Nov-29 9:20:39 AM] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<system-viewEnter system view, return user view with Ctrl+Z.>>>[2011-Nov-29 9:20:39 AM] Start detecting command echo in echo buffer...[2011-Nov-29 9:20:39 AM] Echo is detected, EchoBuffer = <<<system-viewEnter system view, return user view with Ctrl+Z.>>>[2011-Nov-29 9:20:39 AM] Remove Prompt - prompt not found via RegEx[2011-Nov-29 9:20:39 AM] Echo and prompt are removed if they exist, out buffer = <<<Enter system view, return user view with Ctrl+Z.[Quidway]>>>[2011-Nov-29 9:20:39 AM] Start check prompt for menu-based device[2011-Nov-29 9:20:39 AM] Process Line = <Enter system view, return user view with Ctrl+Z.>[2011-Nov-29 9:20:39 AM] Fuzzy match detector start detecting prompt. String1=entersystemview,returnuserviewwithctrl+z. String2=<quidway>[2011-Nov-29 9:20:39 AM] Save Command Output: Enter system view, return user view with Ctrl+Z.[2011-Nov-29 9:20:39 AM] Process Line = <[Quidway]>[2011-Nov-29 9:20:39 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:39 AM] Pushing back: <[Quidway]>[2011-Nov-29 9:20:39 AM] mPrompt is : <<Quidway>>[2011-Nov-29 9:20:40 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:40 AM] Pending Disconnect = False[2011-Nov-29 9:20:40 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:40 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:41 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:41 AM] Pending Disconnect = False[2011-Nov-29 9:20:41 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:41 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:44 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:44 AM] Pending Disconnect = False[2011-Nov-29 9:20:44 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:44 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:44 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:45 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:45 AM] Pending Disconnect = False[2011-Nov-29 9:20:45 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:45 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:45 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:47 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:47 AM] Pending Disconnect = False[2011-Nov-29 9:20:47 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:47 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:47 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:50 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:50 AM] Pending Disconnect = False[2011-Nov-29 9:20:50 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:50 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:50 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:51 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:51 AM] Pending Disconnect = False[2011-Nov-29 9:20:51 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:51 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:51 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:54 AM] TimerTick: mstrData=<[Quidway]> State=3 - Connected to server - idle[2011-Nov-29 9:20:54 AM] Pending Disconnect = False[2011-Nov-29 9:20:54 AM] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...[2011-Nov-29 9:20:54 AM] Fuzzy match detector start detecting prompt. String1=[quidway] String2=<quidway>[2011-Nov-29 9:20:54 AM] TimerTick: Just tick-tockin away. ..[2011-Nov-29 9:20:54 AM] Disconnected - From: 10.180.25.100[2011-Nov-29 9:20:55 AM] Disconnecting
bump
Hi,,I use NCM can detect the device of Quidway R2621 Router,but it can't export running-config,can you help me?eg:
System Description Quidway Router R2621 Huawei Versatile Routing Platform Software VRP (R) software, Version 1.74 Release 0112System Contact System Location System OID 1.3.6.1.4.1.2011.1.1.1.2621Vendor HUAWEI Technology Co.,LtdMachine Type HUAWEI Technology Co.,Ltd
