My understanding is HuaWei are equivalent to 3Com and there are templates in the content sharing zone for those switches. See this link for extending Cirrus device support:
Can you post a list of commands required to show the running config and we'll see what we can do?
www.mibdepot.com/.../vendor_index.cgi
this website maybe helpful for you
old new old new
show = display show version disp versionBp%x+W3Po0K&j0no = undo show run disp current-configurationIT动力源博客-Blog8v P$U1w\user = local-user show tech-support disp base-information-d]zj*_0end = return show start dispsaved-configurationIT动力源博客-Blog4 F9H5lPL!zexit quito.i0t%D"i0exit logout ctrl+z ctrl+qIT动力源博客-Blogh#\8B(rzuu}q Lrouter rip rip ctrl+p ctrl+eIT动力源博客-Blog R-Y9`n\w drouter ospf ospf no debug all ctrl+dIT动力源博客-BlogR%E8^,L4br(Ay*IUrouter bgp bgpIT动力源博客-Blog'C/h%q:vEhostname sysnameIT动力源博客-BlogH8B|1[%r!dA Saccess-list aclIT动力源博客-BlogmL1Cl)yXwrite saveIT动力源博客-BlogruYY"Q.eberase deleteIT动力源博客-Blog|A:`._i@%h#^0 simpleIT动力源博客-Blog~%B8mGMs2d(k7 cipherIT动力源博客-BlogBFaePshost ip hostIT动力源博客-Blog/o%el+YCgrlogging info-centerp)X%b,k-f5Q0encap link-pro
show display show version disp versionBp%x+W3Po0K&j0no undo show run disp current-configurationIT动力源博客-Blog8v P$U1w\user local-user show tech-support disp base-information-d]zj*_0end return show start dispsaved-configurationIT动力源博客-Blog4 F9H5lPL!zexit quito.i0t%D"i0exit logout ctrl+z ctrl+qIT动力源博客-Blogh#\8B(rzuu}q Lrouter rip rip ctrl+p ctrl+eIT动力源博客-Blog R-Y9`n\w drouter ospf ospf no debug all ctrl+dIT动力源博客-BlogR%E8^,L4br(Ay*IUrouter bgp bgpIT动力源博客-Blog'C/h%q:vEhostname sysnameIT动力源博客-BlogH8B|1[%r!dA Saccess-list aclIT动力源博客-BlogmL1Cl)yXwrite saveIT动力源博客-BlogruYY"Q.eberase deleteIT动力源博客-Blog|A:`._i@%h#^0 simpleIT动力源博客-Blog~%B8mGMs2d(k7 cipherIT动力源博客-BlogBFaePshost ip hostIT动力源博客-Blog/o%el+YCgrlogging info-centerp)X%b,k-f5Q0encap link-pro
enable password=super password
Based on the commands you've shown, it should be relatively easy to create a new template and modify it for use with your Huawei device. There's a technical reference posted here that describes this process:
Please have a look and try and if you run into problems, we can troubleshoot further.
Why NCM V5.1 doesnt supports HuaWei Devices?
I believe this is due to a current restriction placed on the sale of Huawei devices in the US coming out of a legal settlement which was in turn due to Huawei allegedly taking some of the code from the Cisco IOS to assist in the writing in their VRP, versatile routing platform, (Huawei's version of IOS). They then merged with 3COM to form H3C as a way into the US market, however it was recently dissolved. The devices that came out of that partnership may have open MIBs, however for the most part, Huawei's MIBs are private and change after every release. They have a very large deployment in Trinidad and Tobago and an even larger deployment in Brazil. It will be nice to see these devices supported however as they are becoming easily accepted in the developing countries due to reduced costs and shorter ROIs. Has anyone created a template for these devices, I would like to get in contact with anyone with the same experience as we have to do same and it would be helpful if I can find others here on Thwack with the same goal, perhaps we can assist each other. I am going to try to build a template within the next few weeks, it would be nice to have some assistance.
