I have an interface on a Cisco ASA that suggests it's transmitting at several hundred Petabits Per second on a Gigabit interface.
The interface is set to use 64 bit counters and we use Counter Rollover Method 1.
Any ideas what might be causing this?
Byron, can you open a support ticket so we can investigate further what is going on here.
Someone else recently started a thread about the same thing. They said the issue is resolved in v10.1. That thread is here:
Ah, thanks. I have been holding off on the upgrade until the dust settles a bit.
Yeah, I've been waiting for the dust to settle too.
I am now running on the most current version of Orion NPM but am still experiencing this issue on some of my network devices; most recently on a Cisco ASA. This node does have 64bit Counters enabled and my Counter Rollover is set to Method 1.
Can somebody please explain what is causing this and what I might be able to do in order to fix it?
I have a new screenshot below...
As noted in my last post, this is still a problem on the most current version of NPM.
Any update to this, I just ran into the same thing. I don't think our ASA was pushing 4.5 Gbps of data on a 1 Gbps link. Most of the spikes seem to be in the 500 Mbps range but there is no way we could generate that much traffic.
If you haven't already; enable 64bit Counters on the device and change your Counter Rollover Method to 2.
Let me know if this helps!
If you haven't already; enable 64bit Counters on the device and change your Counter Rollover Method to 2.Let me know if this helps!
Thanks, but both were already in place.
I have a few older Cisco Switches that do this as well. I found disabling 64 bit counters fixed it. I am guessing the 64 bit counters are broken on the device software.
Yeah, I also had this issue with some older Cisco gear.
Ultimately playing with the 64 bit counter setting and the Counter Rollover Method settings are unable to resolve your problem, I would open a support ticket with SolarWinds.
I tried setting the counter back to 32 bit. The device shouldn't be able to send more that 50 Mbps of traffic anyway.
