what is the "default summary view" for under the edit account?
thjanks
That's the view you see when you click Home on the menu. The default it what we ship. But you can build different summary views for different accounts.
Hmmm. When I edit this Default Summary View to something other than the view chosen for the Home page, the view chosen for the home page loads when I click Home link in the Menu bar.
IS this a bug?
Denny?
I think you need to customize the menu bar to acheive what you want. Scroll to the bottom of the "Select Menu Itmes to add ...Menu Bar" page and click on Add Custom Menu Item and create a Menu button for the view you created. Name it what you wish- Submit and then delete out the previous "Home" menu item.
Thanks Mark. I can certainly do that. But, I still don't understand what the Default Summary View is there for.
For instance, I have a Home Page called "MyHome" and I also have another summary type view called "OtherHome". When the user clicks on the Home link in the menu bar, they are taken to the view listed for the Home Page View.
However, if I designate the OtherHome view as the Default Summary view, when would that view ever be used?
MArk? See what I mean?
Yes I do. It seems to me that it's a bug.
Thanks Mark. I will operate on that assumption in case anyone asks me.
Has this issue (bug) ever been resolved? I have a customer requirement to allow them visibility to their equipment only. I have created the account and views for the customer but on their main log in page there is a home link above the Map (not the tab bar...was able to fix that). Clicking on the Home link takes them back into the main screen with all of my network. I cannot see where to clear that or edit it to have them go back to their personal 'Home'. It doesn't seem like I can do anything in the Default Network Summary section, like adding another specific view to it. Ant suggestions?
