Has anyone gotten Switch port mapper to work with a juniper ex switch.
I keep getting mib bridge not support.
Is ther a switch port mapper that will work with juniper switches
I have . Are you using the WorkspaceStudio version of the SwitchPortMapper?
--Greg
I've been trying to get switch port mapper to work with Juniper EX 4200 switches and I keep getting "do you have read/write snmp enable?" failures. Are you using snmp v3? If so what are your v3 communitry string settings on the Juniper switch? Thanks..
-Vincent
Hi Vincent - what version of the Switch Port Mapper are you using?
I'm using switch port mapper in version 10 of the Solarwinds Engineers Toolset.
Vincent - Can you tell me what version of 10 (like 10.2 or 10.4)? Also, are you using the Classic version, the Workspace Studio version, or the command line version?
Are you using SNMPv3? Does it work via SNMPv1/2c?
Greg
At the moment I'm off-site so I can get the exact version however, it is in the Workspace Studio and it is the GUI version. I can get that information for you tomorrow. Also I am using V3 and I haven't tried V1 or V2 because they don't meet the security requirements needed for this specific installation. Thanks...
The Switch Port Mapper version is 10.4.0.57. Thanks.
isomvc - can you email me a packet capture and the auth and priv passwords (so I can decode in the sniffer?)
I'm running 9.2 and applied the latest mib.cfg. The mapper works with an EX4200, but I don't get any MAC addresses or IP addresses. Does this work on any release?
-=Dan=-
