Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SNMP Port. Alternative Ports?
francismcphail
Was just wondering if it's possible to use other UDP ports than 161 for SNMP polling?
We are currently polling external networks via the Internet, on the external routers we are suing port UDP 161, and forward as needed incrementing UDP ports 162, 163, etc... through to other decives on the internal network we wish to monitor. Can't seem to see a way to change the default SNMP port.
Cheers.
Francis.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
As far as I know, you can't change this, but if you call the support line, perhaps they have a patch or util
that can allow you to do this?
-=Cheers=-
NG
iunderwo
Maybe this could be encoded in a URL of some kind now that the program has dynamic capabilities by name. Something like snmp://192.168.3.3:163.
// Ian Underwood - Service Management
// Level 3 Communications
francismcphail
No luck with SolarWinds tech support. The information I recevied back from them is that is was not implimented. Which I think is a little strange.
As for encoding it in a URL type string no luck with that either. Pitty it can't handle other SNMP ports as I might have to go back to using CACTI.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
