I've added some custom properties using the Custom Property Editor.
When I open the NPM console and go to Admin > Node Management > Edit Properties the custom properties I added don't show up.
Any Help?
M
Did you assign the properties to the applicable interfaces, nodes or volumes in the Custom Properties Editor?
Thanks for the reply.
Yes, as far as I can see they are assigned to the nodes. Attached are the relevant screen shots.
Hmmmm. maybe change the property name to IBM and make it a yes/no type.
Hmmm....I could do that but then I would have to do the same for all of the other nodes that are from various other vendors (not shown in my screen shot)
My aim is simply to be able to group by DeviceVendor (several nodes currently come up as "Unknown")
I See. DeviceVendor did not work for me but Device_Name does.
Nope...no joy...
Doesn't seem to matter what I add as a custom prop...doesn't show up...
Is it possible I need to restart/refresh orion in some way?
It looks like you are in the Edit Properties section of the Node view. Do you see the Custom Prop in the Node view? I am using ver 10.0
In the node details view from the console, the custom props don't show up.
I'm using ver 10
Well, you've got me stumped. You might clear the browser cache and restart the browser. If that does not work I suggest you open a ticket.
Have you tried updating report schemas?
