From the Web Interface:
Is there a way to acknowledge an alert?
Is there a way to show WHO acknowledged the alert?
It's not a view, it's a resource callled "All triggered alerts". It's on the home page by default.
I was just about to submit a request for this exact same thing. Being with a large company there are many network people that acknowledge alerts and should not. I need a way to find out who acknowledged the alert and when.
I don't want to acknowledge basics alerts so yo uare correct there; however, if I have multiple network people across the country or even another continent, can I see who acknowledged an alert there? I would like to see who is acknowledging advanced alerts; who, what time and any other info that would be helpful. Any thoughts on this?
Is this available in V9 only? I am using V8.5 and due to some issues with SW still don't want to just upgrade and have more issues. I looked in my web console and saw the ack alerts but did not see any that had names next to them as in your screenshot.
We're on 8.5.1 SP3. You'll only see names if a user (who has rights to) acknowledges the alert either in the web console or in the Advanced Alert manager on your Orion server. If no one has acknowledged the alert, there won't be a user name or time in those columns.
To acknowledge the alert in the web console, the user needs to check the box next to the alert they want to acknowldge and then click the Acknowledge Alerts button. In the Advanced Alert manager, the user simply needs to click the check box next to the alert in the Acknowledged column.
We are on 9.1 SP3 and I have the following question:
Our company has grown and lots of people now use solarwinds. on our front page in one of the collums we have Active Alerts: All Triggered Alerts which is great for showing alerts that are active, it does also still shows all the aknowledged alerts. Is there anyways that this resourse can only show non aknowledged alerts? this would enable us to easily see what faults have not been picked up?
we plan to fix this bug, probably for the next major release.
Is this still available in 9.5? I cannot seem to find this view anywhere.
I also need to do the same thing for events....
