Upgraded to NetFlow 3.1 .. additional databases are created:
Can anyone tell me why besides "to improve speed and reliability" ?
By dividing the database in filegroups, it allows SQL Server a lot more freedom in how it grows these different files. It also gives customers who are seeking to improve their performance further, the ability to move these filegroups on different diskdrives. Finally, one customer request that we've seen, is for all there NetFlow data to be located in another database. Although, we decided not to move it into another database at this point in time, we tried to accomidate part of their request, by using filegroups. They then can store their netflow database on another disk.
David
I think they broke it up to load graphs faters.
The FG1 stores the FlowCorrelation Pre/Post table
FG2 - SearchBy Tables
FG3 - Summary 1,2,3 Tables
FG4 - Details tables
Yann
Thanks that does help! So should everything have moved to the new filegroups because my old primary filegroup still has tables in it. Are these no longer needed or should they be relocated to one of the new filegroups? Here is a listing of some (not all) the tables and their filegroups.
table_name filegroup
FlowCorrelationPostDNS FG1
FlowCorrelationPreDNS FG1
NetFlowEndpoints FG1
NetFlowSearchByAddress FG2
NetFlowAddressToResolve FG3
NetFlowSummary1 FG3
NetFlowSummary2 FG3
NetFlowSummary3 FG3
NetFlowDetail_1049_1373337 FG4
NetFlowDetail_1049_1373338 FG4
NetFlowDetail_1049_1373339 FG4
NetFlowDetail_1049_1373340 FG4
NetFlowDetail_1049_1373341 FG4
NetFlowDetail_13_1373337 FG4
NetFlowDetail_13_1373338 FG4
NetFlowDetail_13_1373339 FG4
NetFlowDetail_13_1373340 FG4
NetFlowDetail_13_1373341 FG4
NetFlowDetail_1459_1373337 FG4
NetFlowDetail_1459_1373338 FG4
NetFlowDetail_1459_1373339 FG4
NetFlowDetail_1459_1373340 FG4
NetFlowDetail_1459_1373341 FG4
NetFlowDetail_1486_1373337 FG4
NetFlowDetail_1486_1373338 FG4
NetFlowDetail_1486_1373339 FG4
NetFlowDetail_1486_1373340 FG4
NetFlowDetail_1486_1373341 FG4
NetFlowDetail_406_1373337 FG4
NetFlowDetail_406_1373338 FG4
NetFlowDetail_406_1373339 FG4
NetFlowDetail_406_1373340 FG4
NetFlowDetail_406_1373341 FG4
NetFlowDetail_407_1373337 FG4
NetFlowDetail_893_1373339 FG4
NetFlowDetail_893_1373340 FG4
NetFlowDetail_893_1373341 FG4
NetFlowDetail_918_1373337 FG4
NetFlowDetail_918_1373338 FG4
NetFlowDetail_918_1373339 FG4
NetFlowDetail_918_1373340 FG4
NetFlowDetail_918_1373341 FG4
Accounts PRIMARY
ActionDefinitions PRIMARY
ActiveAlerts PRIMARY
AlertActions PRIMARY
AlertDefinitions PRIMARY
AlertLog PRIMARY
Alerts PRIMARY
AlertStatus PRIMARY
AlertSuppression PRIMARY
AlertTestLog PRIMARY
AlertTests PRIMARY
AlertTriggerMap PRIMARY
AlertValueChanges PRIMARY
APM_Application PRIMARY
APM_ApplicationStatus_Daily PRIMARY
APM_ApplicationStatus_Detail PRIMARY
APM_ApplicationStatus_Hourly PRIMARY
APM_ApplicationsToDelete PRIMARY
APM_ApplicationTemplate PRIMARY
APM_BusinessLayer PRIMARY
APM_Component PRIMARY
APM_ComponentDataToDelete PRIMARY
APM_ComponentDefinition PRIMARY
APM_ComponentDefinitionCategory PRIMARY
APM_ComponentDefinitionCategoryMembership PRIMARY
APM_ComponentDefinitionSetting PRIMARY
APM_EventType PRIMARY
APM_ExternalSetting PRIMARY
APM_PortEvidence_Daily PRIMARY
APM_PortEvidence_Detail PRIMARY
APM_PortEvidence_Hourly PRIMARY
APM_ProcessEvidence_Daily PRIMARY
APM_ProcessEvidence_Detail PRIMARY
APM_ProcessEvidence_Hourly PRIMARY
APM_ResourceEvidence_Daily PRIMARY
APM_ResourceEvidence_Detail PRIMARY
APM_ResourceEvidence_Hourly PRIMARY
APM_Threshold PRIMARY
Applications PRIMARY
ApplicationStatistics PRIMARY
CiscoBuffers_Daily PRIMARY
CiscoBuffers_Detail PRIMARY
CiscoBuffers_Hourly PRIMARY
ConstituentPorts PRIMARY
CPULoad_Daily PRIMARY
CPULoad_Detail PRIMARY
CPULoad_Hourly PRIMARY
CustomPollerAssignment PRIMARY
CustomPollerEnums PRIMARY
CustomPollerLabels PRIMARY
CustomPollerParsers PRIMARY
CustomPollers PRIMARY
CustomPollerScratchStatistics PRIMARY
CustomPollerStatistics_Daily PRIMARY
CustomPollerStatistics_Detail PRIMARY
CustomPollerStatistics_Hourly PRIMARY
CustomPollerStatus PRIMARY
DefaultServicePorts PRIMARY
DeletedCustomPollers PRIMARY
DeletedInterfaces PRIMARY
DeletedNodes PRIMARY
DeletedVolumes PRIMARY
dtproperties PRIMARY
Engines PRIMARY
Events PRIMARY
EventTypes PRIMARY
ExternalWebsites PRIMARY
FlowAnalysis PRIMARY
FlowEngines PRIMARY
FlowStats PRIMARY
InterfaceCustomPollerJobs PRIMARY
InterfaceErrors_Daily PRIMARY
... etc
No. Most of the tables should still live in the PRIMARY filegroup. Only the large sized NTA tables have been moved off into these new filegroups. The tables listed here are in their proper filegroups.
thanks David. I think I have what I need for our DBAs. the changes made to netflow from 3.x to 3.1-SP1 has really improved reliability and performance of both Orion and it's Netflow analyzer.
thanks, again.
-Jr.
I have a question about these new filegroups. I have uninstalled netflow, and either deleted or truncated all of the netflow-related tables. However, the FG1 and FG3.mdf files are still huge and I need to get rid of that data. I was told by SW not to mess with the new filegroups, just to delete/truncate the netflow-related tables. How can I reclaim the space? I am assuming that only netflow data is in these FG#.mdf file groups. Thanks.
Debbi
If you have deleted the data from the tables contained within those filegroups, then performing a shrink on those filegroups should reclaim the space. You can do this from Management Studio, by right clicking on the database then Tasks\Shrink\Files. This brings up the "Shrink File" dialog. Then in the Filegroup combobox, select the filegroup to shrink and hit Ok.
Thanks,David
Personally, I 'm a little confused by this response. Can NetFlow data be stored in a database that is physically separate from the Orion database, or must it still be installed in the same physical location?
Are you actually talking about the ability to install the FGs on independent disks of a RAID array as long as the array is the one that Orion is on?
Finally, does you answer apply to 3.1 and 3.5?
Thanks you for clarifying this, because that documentation is indeed extremely deficient in this area.
