Does anyone know if I should be able to view wireless clients on this device? It does show as an access point under the wireless tab but unlike our Cisco AIR 1130, no clients are listed. Running version 9.5.1
Jerry
It should I believe, can you open a support ticket please
Thanks Brandon. A ticket is open and I'm awaiting a response.
Did you get anywhere with the Cisco WAP4410N pulling through the SSID's and Client?
Papitts--
I found Jerry's old case in our support logs. The first fix was to upgrade to 10.0 SP1. If that doesn't fix it, Support gives further instructions, but unfortunately, Jerry did not report back with his final status so I don't know if they will work for you.
What version of NPM are you running?
M
Hi Marie,
Our NPM is currently on 10.1.2 SP1
Paul
Hi papitts--
Here are the additional instructions. You'll do them in preparation for talking with Support, who you will have to call unless the Community chimes in:
When you open a support ticket, could you:
--Reference this thread to Support.--Post back here with a case number.--Post any solutions you get from Support.
Let me know if these help you,
M,
Thanks for your reply, I have followed your instructions and opened a case, 241744 and submitted the snmp walk output with a client connected to the access point.
Will post back with any solutions from Support.
Hi ">papitts, did you have some solution for that, I´m with tha same problem.
Tks,
Best Regards,
Fernando
Hi Fernando,
This still isn't working on our Orion, the ticket I raised with support ended up with it being submitted as a feature request.
Cheers,
Was this ever resolved? I have the same problem.
I have version 2012.2.2 and it shows that the WAP4410n constantly rebooting. It isn't at a constant interval, just random events.
The WAP has not rebooted as I was connected with my laptop and using it during some of the reboot times reported by Solarwinds.
From Solarwinds I cannot see any wireless clients that are connected to the WAP either. I think this is a fault of the WAP as it takes long for the WAP to report on clients from the web management page. See here for how to see clients from the WAP:
WAP4410N access point; Can I view connected clients and some other…|2051647 - Cisco Support Community
I would connect my laptop to the WAP and browse the network, but my laptop's WiFi MAC address only displays in the WAP's wireless clients list after ~ 15 min.
Is this a mib issue? or is it just a bad (latest v2.0.6.1) firmware on the access point.
I am actually experiencing this for more devices than the Cisco WAP4410n,
It happens for my APC devices - In-Row Air coolers, PDU and UPS's
Can this be mib related?
