Has anyone created a template for a Nortel 470 switch? It is a menu driven device, so I'm having a lot of difficulty getting it to work with Cirrus.
Thanks!
I'd be happy to work with you on the creation of a template. Can you list all the commands and screen navigations that must be executed to download the config via TFTP?
Have you reviewed the tech ref on creating templates? If so, do you have a template that you've already started for this device?
I have reviewed the tech ref, and found it to be confusing. As I said, I need to have this template completed for management review. When I purchased the product the tech rep assured me that it could handle the Nortel switches, in reading through postings on Thwack, I am starting to think that this is not the case. I am really not sure why there wouldn't be a template for the Nortel 470, it is a widely used switch.
If you could provide me with a template, it would be greatly appreciated.
Is there a template available? Or an idea of the timeframe necessary to provide one?
I'll have a template you can try tomorrow that is based on the commands you sent me. I'd like to setup a web meeting tomorrow to walk through this with you and hopefully get you to a point where you're comfortable with writing templates on your own.
BTW, is {ctrl} really a carriage return new line or do you really have to hit the CTRL button?
I've attached a template you can try.
