I would be interested in the same thing. The ability to monitor performance figures and uptime is useful but failed components would be very useful.
You can with the Custom Poller on v8. If you are interested, I will upload the ProLiant OID's for you.
I have been playing around with the custom Poller's this morning, so it would be great if you could upload the ProLiant OID's?
Rich
I'd be interested in this as well.
Thanks!
I just uploaded a bunch that I use
Check
JB
Hi guys
I have a basic ProLiant ML115.
I've added the custom poller settings to my server but it's not added any new statistics or anything.
I'm a relative newbie to this program and I'm trying to configure some basic monitoring for my RAID system.
Thanks for any info thats offered.
Sorry Mat, the server needs to support the HP Insight Agents to get the OIDs.
It doesn't look like the ML115 does.
Thanks jb,
Bit of a shame about that.
Is there no way to monitor if a RAID fails through Orion then?
Cheers guys
JB,
I have used your pollers and i am getting all results what i wanted too. This post is brilliant and thank you for all your hardwork. Please can you advise ione thing at the moment i am sending alerts using url is it possible to create a basic alerts which tells us that physical drive has failed drive number and bat number. I have tried to create aletrs which send alerts but not meaningfull.
Regards,
