Hi
My solarwinds application displays more objects down or Up. If someone has an idea
help me please. This is really urgent.
Best Regards,
Camel
Can you supply more information?
Is this NPM, SAM, or some other product?
It is the events for NPM
Kind Regards,
Okay, great.
Do ALL nodes show down, or do some show as up?
I rephrase my question: I do not have nodes down or up in the events type.
Excuse me repeat my question several times
Hello rharland2012,
Thank you for the answer but my problem is not solved. I think with the shots below it will solve my problem.
Please help me because I can no longer work because of it.
Camel TALLA
please run configuration wizard on orion. Hopefully this will resolve the issue.
thanks,
Syed
Hi Syed H,
My problem is not resolved.
Please help me
I think the fastest fix for you right now is to open a support ticket with SW. They can more quickly help and provide resolution in this case.
And as a workaround to keep you going with your daily tasks, check the node downs from manage nodes view,
Settings -> Under Node & Group Management (Manage Nodes) -> Group by Filter on left hand side (Select [No Grouping] from drop down) -> Search for 'Down' against Show Nodes.
If you want to drill it down on a daily basis you can create a report or a email alert.
