My understanding is HuaWei are equivalent to 3Com and there are templates in the content sharing zone for those switches. See this link for extending Cirrus device support:
Can you post a list of commands required to show the running config and we'll see what we can do?
www.mibdepot.com/.../vendor_index.cgi
this website maybe helpful for you
old new old new
show = display show version disp versionBp%x+W3Po0K&j0no = undo show run disp current-configurationIT动力源博客-Blog8v P$U1w\user = local-user show tech-support disp base-information-d]zj*_0end = return show start dispsaved-configurationIT动力源博客-Blog4 F9H5lPL!zexit quito.i0t%D"i0exit logout ctrl+z ctrl+qIT动力源博客-Blogh#\8B(rzuu}q Lrouter rip rip ctrl+p ctrl+eIT动力源博客-Blog R-Y9`n\w drouter ospf ospf no debug all ctrl+dIT动力源博客-BlogR%E8^,L4br(Ay*IUrouter bgp bgpIT动力源博客-Blog'C/h%q:vEhostname sysnameIT动力源博客-BlogH8B|1[%r!dA Saccess-list aclIT动力源博客-BlogmL1Cl)yXwrite saveIT动力源博客-BlogruYY"Q.eberase deleteIT动力源博客-Blog|A:`._i@%h#^0 simpleIT动力源博客-Blog~%B8mGMs2d(k7 cipherIT动力源博客-BlogBFaePshost ip hostIT动力源博客-Blog/o%el+YCgrlogging info-centerp)X%b,k-f5Q0encap link-pro
show display show version disp versionBp%x+W3Po0K&j0no undo show run disp current-configurationIT动力源博客-Blog8v P$U1w\user local-user show tech-support disp base-information-d]zj*_0end return show start dispsaved-configurationIT动力源博客-Blog4 F9H5lPL!zexit quito.i0t%D"i0exit logout ctrl+z ctrl+qIT动力源博客-Blogh#\8B(rzuu}q Lrouter rip rip ctrl+p ctrl+eIT动力源博客-Blog R-Y9`n\w drouter ospf ospf no debug all ctrl+dIT动力源博客-BlogR%E8^,L4br(Ay*IUrouter bgp bgpIT动力源博客-Blog'C/h%q:vEhostname sysnameIT动力源博客-BlogH8B|1[%r!dA Saccess-list aclIT动力源博客-BlogmL1Cl)yXwrite saveIT动力源博客-BlogruYY"Q.eberase deleteIT动力源博客-Blog|A:`._i@%h#^0 simpleIT动力源博客-Blog~%B8mGMs2d(k7 cipherIT动力源博客-BlogBFaePshost ip hostIT动力源博客-Blog/o%el+YCgrlogging info-centerp)X%b,k-f5Q0encap link-pro
enable password=super password
Based on the commands you've shown, it should be relatively easy to create a new template and modify it for use with your Huawei device. There's a technical reference posted here that describes this process:
Please have a look and try and if you run into problems, we can troubleshoot further.
Why NCM V5.1 doesnt supports HuaWei Devices?
