Has anyone been able to install ipMonitor 9 on Windows 2008 server. I just installed the eval I downloaded from the web site and the service won't start.
Thanks.
I don't believe that is supported. Currently only Windows Vista (IPv4 mode only), Windows XP SP2 or later, Windows Server 2003 SP1 & R2.
www.solarwinds.com/.../ipMonitor_v9_Datasheet.pdf
That's correct. We're planning on adding support for Windows 2008 in a future release. To help us prioritize, we'd be interested to know our customers' deployment timeframes for Windows 2008. Are you just kicking the tires right now? Or is it a 2009 project?
We have been using ipMonitor for 3 years now. It's time for us to retire our old apps and servers and upgrade. We are deploying all of our new servers based on Windows 2008. We will deploy ipMonitor as soon as it's available for Windows 2008. When do you expect your next release?
We hope to have a 2H08 release, but our current thinking was to only support monitoring Windows 2008 servers not running on them.
Are there others out there that require the ability to host ipMonitor on Windows 2008 servers? If so, please post to help us prioritize.
We are likewise solely using Windows Server 2008. It's great that you can monitor the server, however, being able to run the software from a central server is very important. Desktops turn off frequently enough to not be viable as a monitor station.
Is there an ETA for a release?
Chris,
Will ipMonitor be able to run on a Win 2008 virtual machine that is part of a HyperV cluster?
HyperV should not have any impact if ipMonitor supports Windows 2008 as a host OS, but we'll ensure we do some testing in that configuration.
Is it still planned for early 2009 for Server 2008 support. We too are moving to Server 2008 very quickly.
Hi, was wondering if there is support for IPmonitor on Win2008 (better yet, R2) ... the last post was dated Oct. 2008, but here we are in 2010 -- any word?
Version 10 has Server 2008 32-bit as a supported OS. No word on R2 or 64-bit. It would be nice to have official 64-bit OS support since that's where we're all headed anyway.
