Has anyone managed to get Storage Profiler to work with a Dell/EMC AX4?
Yes, we have had success with the AX before, and have validated support with EMC. The only difference is the AX does not provide performance statistics.
Brian
Yes, it should work fine for an AX4 array. If you are facing any issues gathering information?
I was trying to use our EMC SMI-Provider, but it would not accept either teh AX4's IP or serial number. Is there another method for monitoring it?
SMI-S is the way to do it. If you have already followed the instructions as per page 17 of this doc http://www.solarwinds.com/support/profiler/docs/SMISProvider.pdf (which is also in the product help) and looked at the Troubleshooting FAQ that follows, please open a support ticket (http://www.solarwinds.com/support/ticket ) and post the case id back to the forum
DirtySouth--
If you do open a support ticket, please also reference this thread and post any solutions you get from Support.
Many thanks,
M
I've followed those steps. They worked fine when adding our NS-120 a year ago. When I attempt to add one of our AX4's, I get error, "HTTP Error (401 Authorization Requred)." I know for a fact that I'm using the right credentials.
Are you certain this works if the AX is running Navisphere Express?
You need to make sure that the SMI-S provider can communicate with the Storage Array.Run the TestSmiProvider.exe \Program Files\EMC\ECIM\ECOM\bin and connect to the AX4Once you connect you generate a key file which enables communication between the server running the SMI-S Provider and the Storage Array.
In Profiler, under Resource Configuration for the Storage Array, make sure you've got the following filled out correctly under SMI-S field:
Status: OnCIM Namespace: /root/emcUsername: adminPassword:Provider IP address: <IP address of server with SMI-S provider installed>Provider HTTP Port: 5988 (Make sure this port is not blocked)Provider HTTPS Port: 5989 (Make sure this port is not blocked)Serial No: this you get after running a testProvider Cimom Namespace: /interopProvider Vendor Namespace: /root/emcTemplate: EMC ClariionIf you are using Navisphere Express and would like to get performance statistics then you will have to enable the following in the Storage Array's web console:
System > Services > Diagnostic Files... > Performance Logs...Click start to start logging performance metrics. The logging only lasts for 7 days so you will have to manually start logging again after each 7 day period.In order to log indefinitely, you need to upgrade Navisphere.HTH
When I run the addsys command from the TestSmiProvider.exe, I get an error saying "HTTP Error (401 Authorization Requried)". I know for a fact the username/password I entered is correct because I can login to the AX4 using the same credentials.
I'm not following you on where you're seeing the "SMI-S field" configuration stuff. Also, I've read through the SolarWinds documention a dozen times and I don't see anything about generating a key. Maybe I'm missing something simple here.
· Requires a login to powerlink - https://powerlink.emc.com
· Location: Home > Support > Software Downloads and Licensing > Downloads S-Z > SMI-S Provider
· Download the latest provider available.
With regards to the SMI-S Field, first you need to add the Storage Array then click on the spanner belonging to the resource:
