I have Orion 1.9 it installed great. I deinstalled 1.9 to put in 1.10 but 1.10 fails installation right at the end of install then it rolls back
Can you please let me know the OS details of the machine you are trying to install 1.10.
Hello, it's not very usual. Are there some leftovers in the install folder (c:\Program Files (x86)\SolarWinds\Orion SDK\) if so, can you delete them and try to install again? Moreover the uninstall before installing is not required. Classic upgrade using the installer should work without issues.
Windows 7 Prrofessional 32 bit
When I removed the old sdk there was no more solarwinds folder and it chokes on upgrading.
Few things I'm thinking about:
H.
sent you event log and yes i logged in as administrator still nogo
Could you, please, tell me where you sent it? My THWACK inbox as well as e-mail doesn't contain any message from you. Or can you resend it?
jive-1046919403-3vb5-2-5lkk@solarwinds6.hosted.jivesoftware.com i get an ndr from this email
That's bad. Can you share it somewhere (dropbox, google drive) and send me the link as personal message?
OR
Could you confirm you're using the 32bit OS on your SDK environment? Maybe we found a bit random problem on 32b systems. We will fix that and provide, but need to know if there might be another issues to fix. Many thanks. Meanwhile please use the SDK 1.9
Regards,
Windows 7 Professional 32 bit. Kaiser doesnt allow dropbox or google drive. if there is another email i could send it I have the application log
Problem found in installer and fixed. Thanks to Thomas for help. SDK 1.10 available here
