I have orion npm 8.1.0 installed. My website runs soo slow. Any ideas?
you can try
Thanks for the info, but that didnt work. It a hp g5 sserver fresh build. I am thinking it might have something to do with the setup
I would strongly recommmend upgrading to NPM 9.1 SP1. Web performance is much better in the current version than in 8.1.
Yeh. Thats a $3000 solution I cant afford right now.
Understood. If you're looking for more help, you'll get farther with more details about your environment e.g., -- hardware, database specs, load times by resource, etc.
HP PROLIANT G3
xeon 3.06ghz
2 gb ram
sql 2005
Igig memory
2K3 Standard
spacefrowns, what resources do you have loaded on you home page?
How many elements are you monitoring etc.
I have tried the procedure of loading the home page and timing it. then clearing the web cache and clicking on each item and timing how long each one loads. Mine takes 5 to 6 seconds to load the home page, i clear the webcache on the server and then try clicking on each item on the home page and they all take less than 2 second. but i have determined that the map is the problem, i just dont know how to fix it. Management wants the map on the home page.
