quote:Originally posted by wtfunkFolks,I'm new to this, so excuse my ignorance in advance:) I also couldn't find a similar thread, so please provide a link if this has already been discussed.I have Orion V8 - Eval. I'm trying to send traps to it from a non-recognized/supported device. It can't see those traps. Here are my two questions:1) How can I verify the trap receiver is functioning on Orion? I don't want to poll the device, just receive traps from it.2) How can I import the trap definitions for my device?Thanks,Funk
I have the same problem. I ran a sniffer on the orion server and the traps are getting to it but the trap viewer doesnt display them. Does anyone know the fix?
hueyii,
I'm having the same problem. I saw a comment that the database needs to be SQL2000. Have you figured out the answer?
Rob
One suggestion to try would be to use the port scanner to verify that you do not have more than one app listening on port trap UDP 162-
I used the port scanner from the SolarWinds Engineering tool set and interestingly enough it says that the port is closed even though the trap receiver continues to tick off received traps.
How would multiple apps be detected with a port scanner?
The SolarWinds port scanner did not allow me to differenciate between UDP and TCP..
I am running both the SolarWinds and Microsoft SNMP trap service. Could this be causing problems?
Thanks for your help!
I have the same problem with them both installed on the same system - does your event viewer say anything like this? I'm wondering if we can disable the toolset receiver and only allow the orion one.
