Hi All,
I need to Custom SQL query to get all triggered alerts(emailed alerts) in past 24 hours. I tired working in report writer as i am very new to SQL not able to completed. Can any one please help me out
Was the output in Alert Manager insufficient or in the wrong format? It's very easy to display them there . . .
When i tried running the query no output is generated , even there are some email alerts on the same day.
There is one report available by default...did u check that?
I ensure that any alerts I'm interested in reporting on are [trigger action] NPM Event logged with desired info, then I just query the events table with appropriate WHERE criteria
Yes, using that I am not getting all email triggered events
I am only getting website components alerts, not on custom SQL query, high CPU usage and etc
What products and versions of SolarWinds do you have installed currently?
-ZackM
I am using SAM 6.2 version
You could try these:
SQL for All Alerts per Object:
SELECT Name 'Alert Name' ,EntityCaption 'Object of Alert' ,COUNT(1) 'Times Alert Triggered'FROM AlertHistoryViewWHERE EventTypeWord = 'Triggered'AND TimeStamp > (GETDATE()-1)GROUP BY Name, EntityCaption
SQL for All Alerts:
SELECT Name 'Alert Name' ,COUNT(1) 'Times Alert Triggered'FROM AlertHistoryViewWHERE EventTypeWord = 'Triggered'AND TimeStamp > (GETDATE()-1)GROUP BY Name
Both of these will count the number of times an alert has been triggered in the last 1 day.
Thanks Zackm, What i need to get all the triggered email alerts to display for last 24 hours. I tried your above query but not worked for me.
Please share the query that get the output of all the triggered email alerts in last 24 hours.
I'm not quite clear on your request. The queries I gave you will give a list of every alert that was triggered and how many times.
Are you asking for a list of every single alert that was triggered and the associated objects?
If so, try this:
SELECT TimeStamp 'Alert Time' ,Name 'Alert Name' ,ObjectType 'Object Type' ,EntityCaption 'Alert Object' ,RelatedNodeCaption 'Related Node'FROM AlertHistoryViewWHERE TimeStamp > (GetDate()-1)AND EventTypeWord = 'Triggered'ORDER BY TimeStamp DESC
I beleive Events may be a better approach to solving this.
