quote:Originally posted by dsullingerAnyway to setup this script to search for specific interface speeds? I would like to see all interface circuits that are 56 Kbps, or all 1.544 Mbps.
Since upgrading to v8.5.1 sp3 my search button now doesn't work. Looked for all the files to make sure everything is still there and all would appear ok. Any suggestions?
Anyone able to assist. When I use the search tool posted above the page refreshes but I don't see any results or an error either.
Bit of an update. I have now found that the search box works if you detach it from the main view, but if you search whilst its docked in the main summary view it fails to return results.
Really would appreciate some or a steer on this, thanks
Mark
I believe the SW developers have included this code into the OOB search resource already.Just add that view to your page and you should be good to go.Here's a snippet from the V8.1 code here: C:\Inetpub\Solarwinds\NetPerfMon\Resources\9-1-Miscellaneous\99-SearchInterfaces.Resource(V8.5.1 uses ASPX code for this and includes the wildcards for you)
<!-- Title=Search Interfaces --><!-- Advanced=TRUE --><!-- Level=7 --><!-- UpgradePath=/Orion/NetPerfMon/Resources/Misc/SearchInterfaces.ascx --><!--#include Virtual=/NetPerfMon/scripts/Resource.asp --><!--Thanks to Ian Underwood --><!--www2.solarwinds.net/.../topic.asp<% Title="Search for Interfaces" HelpPage="SearchInterfaces" Dim Field Dim AnyInterface DoResourceHeader NetPerfMon.InsertGroupingJava Set AnyInterface = NetPerfMon.GetNetObject(NetPerfMon.GetRandomNetObject("I"))%>
I found something similar in 8.5.1 - I have to enter the search critieria twice before it works (or detach the resource as you say).The first search attempt just clears the search box and kicks me back to the same page.
Thanks for the replies.
Denny, nope I haven't raised a ticket but I will do now.
As a bit of a further update, I have found that all forms act in the same way, one of the guys here wrote a piece that allowed us to update fields in the Custom Properties from one form, stuff like Server Name, Rack ID, Server Owner etc this form will only work when detached from the window. When we make updates with the resource docked in the main page the submit will not work.
