I'd like to request Meru and Trapeze be added to the supported wireless products that NPM monitors.
Another thread about it:
Thanks, I have added you to the feature request
I also request Meru Networks to be added to the supported wireless devices list. 99% of our wireless network is Meru and the only thing I can monitor is the controller. Please add AP support as well, if we cannot monitor our wireless as well as wired network, we will be forced to use another product.
I would also like to see support for Trapeze.
I have added both requests to the list
Another request for support for Trapeze wireless monitoring.
Thank you for the post, got it
Hi!
What is happening with the support for Trapeze WLAN controllers?
There is also a Wireless controller feature in the Juniper SRX series firewall. We are using a SRX240 mutiservice router which controls 5 wireless AP. I don't see anything in the Wireless dashboard.
Has there been any update on trapeze wireless support being added? im on NPM 10.2.2
Has there been any update on trapeze (3com) wireless support being added? We are running NPM 10.2.2.
