Pleaese help me to get list of interface down alerts through swis query.
Try this:
SELECT Nodes.Caption AS NodeName ,Interfaces.Caption AS InterfaceName ,Alerts.Acknowledged ,Alerts.AcknowledgedDateTime ,Alerts.TriggeredDateTimeFROM Orion.Nodes AS NodesJOIN Orion.NPM.Interfaces AS Interfaces ON Nodes.NodeID = Interfaces.NodeIDJOIN Orion.AlertObjects AS Objects ON Objects.RelatedNodeID = Nodes.NodeID AND Objects.EntityURI = Interfaces.URIJOIN Orion.AlertActive AS Alerts ON Alerts.AlertObjectID = Objects.AlertObjectIDWHERE Interfaces.Status = 2
Hey there,
You're looking for the Orion.NPM.Interfaces entity and the query would be the following:
SELECT Nodes.Caption AS NodeName ,Interfaces.Caption AS InterfaceNameFROM Orion.Nodes AS NodesJOIN Orion.NPM.Interfaces AS Interfaces ON Nodes.NodeID = Interfaces.NodeIDWHERE Interfaces.Status = 2
Thanks. It is working fine . Could you help me to get alertobject I'd and
triggered datetime for interface down alerts. Pls help.
Ah I see what you were asking. Sorry about that. Give this a try. You should have access to both the active alert information if you want additional fields and the alert object information so just add to the SELECT clause as needed:
SELECT Alerts.AlertActiveID ,Alerts.AlertObjectID ,Alerts.TriggeredDateTime ,Objects.RealEntityTypeFROM Orion.AlertActive AS AlertsJOIN Orion.AlertObjects AS Objects ON Alerts.AlertObjectID = Objects.AlertObjectIDWHERE Objects.RealEntityType = 'Orion.NPM.Interfaces'
Am using below query to get interface down alerts, but somewhat am getting duplicate value in results, instead of 2 interface down, it is showing as same interface down twice. please hele me to fix this.
results3=swis.query("SELECT ao.AlertObjectID,I.InterfaceName,ac.AlertMessage as Message,ao.RelatedNodeCaption as Node,ao.AlertID as AlertID
from Orion.NPM.Interfaces I inner join Orion.AlertObjects ao on ao.Node.NodeID=I.Node.NodeID
inner join Orion.AlertActive aa on aa.AlertObjectID=ao.AlertObjectID
inner join Orion.AlertConfigurations ac on ac.AlertID=ao.AlertID
inner join Orion.AlertStatus als on ao.AlertObjectID=als.AlertObjectID
WHERE ac.Severity=2 and als.Acknowledged = 0 and ac.Severity=2 and I.Status=2 and ac.AlertMessage like '%Alert me when an interface goes down%'
and I.InterfaceID in (13961,13962,13963,3246,9060,3522,9088,3445,15372,12437,12438,7100,3404,9470,6741,9123,3362,10986,15282,4738,9119,3528,4289,9939,10142,7176,9118,3499,16236,3439,11797,3453,9823,9824,3545,3546,7005,9491,9492,10741,10742,11849,11852,14605,5133,8800,5274,5549,5584,5585,6725,10122,8710,7159,7762,9161,7974,8763,10551,9323,9399,12185,14549,15846,14588,16378,15847,16375,13956,13957,13959,14715,15754,9934,9996) order by aa.TriggeredDatetime desc")
You don't need that additional join to AlertStatus to get the Acnkowledged state - that's in the AlertActive table. Adjust your query like this:
SELECT ao.AlertObjectID,I.InterfaceName,ac.AlertMessage as Message,ao.RelatedNodeCaption as Node,ao.AlertID as AlertIDfrom Orion.NPM.Interfaces I inner join Orion.AlertObjects ao on ao.Node.NodeID=I.Node.NodeIDinner join Orion.AlertActive aa on aa.AlertObjectID=ao.AlertObjectIDinner join Orion.AlertConfigurations ac on ac.AlertID=ao.AlertIDWHERE ac.Severity=2 and aa.Acknowledged = 0 and ac.Severity=2 and I.Status=2 and ac.AlertMessage like '%Alert me when an interface goes down%'and I.InterfaceID in (13961,13962,13963,3246,9060,3522,9088,3445,15372,12437,12438,7100,3404,9470,6741,9123,3362,10986,15282,4738,9119,3528,4289,9939,10142,7176,9118,3499,16236,3439,11797,3453,9823,9824,3545,3546,7005,9491,9492,10741,10742,11849,11852,14605,5133,8800,5274,5549,5584,5585,6725,10122,8710,7159,7762,9161,7974,8763,10551,9323,9399,12185,14549,15846,14588,16378,15847,16375,13956,13957,13959,14715,15754,9934,9996) order by aa.TriggeredDatetime desc
If i run above query, am not getting any results, but interface down alerts are there.
please help.
What happens when you remove the WHERE clause entirely? Do you get rows?
