Is it possible in 8.5 to put all nodes into unmanaged from a certain time to a certain time? I see how to do each individual one.
This is not possible in 8.5, but it's something we plan to add.
Hi Denny
Under a particular node, sometime a WAN connection via Serial or Ethernet or even and edge switch may be offline for maintenance planned or otherwise.
Are SW considering the option to put a particular interface from a node on maintenance mode? A router can have multiple ISP's in any one router and the maintenance times are of course going to be different.
Ken
I believe what you're asking for is the ability to unmanage interfaces. I've requested this very feature in the Orion feature requests located here...
It's definitely on the list.
Any news on this feature?
Still on the list. Not in 9.0.
Any chance for "on the list" for 9.0 SP3? I would add that the ability to unmanage devices *and* groups of devices would be a huge benefit.
Also, the ability to unmanage a device/interface/group *indefinitely* would be helpful.
